electronics on radiator
Tylerberg45
- Year and Model: 1998 s70
1998 Volvo s70 t5. What is the little pump thing on the driver aide of the radiator for? And what lines plug into it? I can't seem to find a diagram. Also the secondary air pump under the battery tray. What line connects to that?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
SAS pump has a line to the airbox and another line to the silver canister at the exhaust manifold at the back of the engine.
Cruise control pump is under the battery, is that what you mean?
'98 S70 T5
2016 Chevy Cruze Premier
- Has thanked: 1613 times
- Been thanked: 4078 times
Could it be the EVAP purge valve you seek?
One electrical connector, two hose nipples.
Tylerberg45
Cruise control makes sense considering it doesn't work. ill worry about this later. I'm currently in the middle of a motor swap and failed to take pictures of where stuff is supposed to go. It runs perfectly but seems to be a little low on power and is getting bad gas mileage. Its possible that its the purge valve.. It is a pump of some sort it moves air and is mounted at an angle on the fan shroud. Idk what lines are supposed to be connected to it.
- Year and Model: Many Volvos
- Been thanked: 76 times
It sounds like you are describing the purge valve but snap a picture of the area in question and post it back.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Is it black plastic or a metal part?
If it's plastic...it's what Lee said.If it's metal...it is part of SAS system.Both have electrical connectors.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Tylerberg45
Ok. I am posting the requests for pictures along with all of my other questions for hoses, electrical connectors and what not. hope this helps!
This looks like EGR gear to me, but Im not an expert on that - 1999 doesn't have of course.
jblackburn
#1 attaches to the vacuum tree area at intake manifold. That is vacuum for the fuel pressure regulator.
#2 attaches to the output of the SAS air pump (under the battery tray)
#3 is the input for the SAS air pump.
#4 ??????????
#5 - attaches to the radiator bracket, you can actually see the mount on the left hand side of your picture. That is the EVAP purge valve, not a pump.
#4 ??????????
'98 S70 T5
- 1240 Views
Last post by Cerutti
- 695 Views
Last post by 93Regina
- 18 Replies
- 8598 Views
Last post by BeachWagon
- 2760 Views
Last post by SuperHerman
- 2270 Views
