1997 850 P0445 code/air pump
Tobers
Year and Model: 850 wagon, 1997
Post by Tobers »
i've been on a search to fix a check engine light. I fixed a rotten, disconnected hose on the back of the SAS valve. I was hoping that would solve it, but that didn't fix it. I put a new SAS valve in, and did the VW air pump trick. That didn't do it, either; I have a P0445 code. And there is a slight fuel smell in the cab (not strong enough, I think, to be an actual fuel leak).
I could do the diode trick, but I'd prefer to try to fix it legally.
Ideas on what to try next? Thank you! Rick
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Is the blower running when you start the car? The SAS really doesn't do much, it heats up the catalytic converter a fuzz faster and that's about it.
Has thanked: 1611 times
Been thanked: 4075 times
P0455 is an evap code, not SAS.
You probably have bad hoses to the evap canister in the fender well (?)
The J hose is often the culprit and the slight fuel smell is a great tipoff.
Well documented in threads and also in the VOlvo repair database here
MikeHotchkiss
Year and Model: 2008
Post by MikeHotchkiss »
Most common cause of an Evap Leak Smell on Volvo S70's is a crack in the "J" hose which is connected the charcoal canister. OTHER causes could be leaks on the Evap Lines and the Purge solenoid(on radiator shroud), but the most common is a cracked J hose which gives off a P0442 OBD2 code.
If a crack is found, replace hose by removing clamps and replace it.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
On my '97 855, the cause of the P0445 code was a nibbled rubber hose at the rollover valve located next to the fuel filter at the rear passenger's end of the car.
