Several reading points to rear cam seal leaking.
So I found it, and it is.
Here are two photos.
When I place the 10mm socket to and turn counterclockwise, the cam moved a little - some 30º.
Should I panic? Is there a need for counterhold, if so what tool?
2001 V70XC - Rear Cam Seal making me nervous
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
No panic. VIDA does not say much about rear camshaft seal replacement. It also does not mention any counterlock. M10's torque is 50 Nm. You may want to hold this adapter in place with hand in a grippy glove while ratcheting the bolt out.
xHeart
Thanks vtl.
I will wrap up with rear cam seal, two o2 sensors, and new coolant hoses.
Torque value is a good clue.
- 1510 Views
Last post by iRenaissanceMan
- 9812 Views
Last post by tyguyc
- 22 Replies
- 10578 Views
Last post by ggleavitt
- 2066 Views
Last post by wizechatmgr
- 745 Views
Last post by goldenreed
