1991 Volvo 240 crankshaft gear removal
vcowens
- Year and Model: 1998 V70, 1991 240
During reinstallation after changing my timing belt and tensioner, I noticed that the crankshaft timing gear's tab that mates to the pulley/damper is rounded off to the point of not stopping the crankshaft pulley from turning 360 degrees on the shaft. I guess it was torqued hard enough where it wasn't an issue. Do I need to replace this gear? How do I pull the gear. Will I have enough space to remove the gear with the engine in the car? Thanks everyone.
BlacJac
- Year and Model: 1990 240 DL Wagon
I know that this is an old thread, but I'm having the same struggle getting my crank gear off. It's on there pretty tight, and there is absolutely no room behind it to get a screwdriver, let alone a puller. How do I get this thing off without damaging something? Also, what is the metal ring directly behind the gear (pictured)? It looks like a dust cover but it's loose and rotates. Is this part of the crank seal?
And while I'm asking all of the questions, should I replace the seal while I'm in here? It's not leaking at all, but there is some residual oil in the area that you can see in the pictures. I'm assuming the answer will be "if it ain't broke don't fix it". But I thought I'd ask.
Thanks in advance for the assistance. -Bob
BlacJac
OK. I figured this out, so if anyone else is facing the same issue here is what I did. I found a good video showing how the process should work: My gear however was frozen in place. So I hit it with penetrating oil several times and ended up tapping the gear very gently with a small hammer to free it. Once it broke loose it slid off very easily.
- 1288 Views
Last post by ducttapeandzipties
- 1580 Views
Last post by XC70Rider
- 1048 Views
Last post by 93Regina
- 1000 Views
Last post by mechanic
- 659 Views
Last post by JDS60R
