1998 s70 Car ramps
JRev
Year and Model: S70 20V 2.5 1998
Post by JRev »
I know any suggestions will be us/canada based but if anyone uses ramps for oil changes can you post a link to the ones you use? just so I can see which ones would be suitable for these cars as I'm looking for some good quality rubber ramps and the best ones seem to be caravan levelling ramps due to the weight they can take.
The steel ones available over here get varying reviews due to them bending, which doesn't give confidence.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I'd suggest a good quality floor jack
with a set of dependable jack stands.
JRev
Post by JRev »
BEJinFbk wrote:I'd suggest a good quality floor jack
I take it you aren't a fan of using ramps or are axle stands your preference?
difflock54
Year and Model: V40 Nordic 2002
Has thanked: 7 times
Post by difflock54 »
Steel ramps should not bend or buckle if they are 'properly weight rated' to suit the vehicle supported and built to reputable required standards.
True that Volvo's are built a bit more solidly and weigh a little more generally.
BEJinFbk
Post by BEJinFbk »
You can do a LOT more with a floor jack and stands.
A jack and stands offer a great deal more versatility.
Try to check your front motor mount with a ramp...
And you'll have a lot more room to work - Case in point:
Floating R.jpg (80.87 KiB) Viewed 1633 times
difflock54
BEJinFbk wrote:You can do a LOT more with a floor jack and stands.
Your quite right but here (NZ) we get earthquakes reasonably regularly and the pic of the vehicle on just the 4 stands doesn't inspire a lot of confidence to be stuck underneath in a good shake. :shock:
Been thanked: 4065 times
I use plastic ramps (ABS) for all my oil changes. I haven't used my metals ones in ages. I use them even on the EV which weighs a lot more the either Volvo. They probably have some service life after which you sell them to a kid with a bike...
JRev
Post by JRev »
Nice! Wasn't doubting floorjack/axle stands offer more possibilities, just simply considering ramps as an alternative method solely for oil changes.
JRev
Post by JRev »
difflock54 wrote:Steel ramps should not bend or buckle if they are 'properly weight rated' to suit the vehicle supported and built to reputable required standards.
These are the ones I nearly ordered (with extensions) as draper are a good brand but read the reviews and done some research on google and not that confident they would be suitable!
http://www.amazon.co.uk/Draper-23302-Pa ... aper+ramps
Been thanked: 504 times
Post by cn90 »
Steel ramps are a pain to use.
Wood ramps are way better, info below...
DIY: 98 V70 Engine Oil Change (& ATF Change): the Easy Way!
https://www.matthewsvolvosite.com/forums ... hp?t=42989
