Why do my dash lights do this?
That's the ECc control unit telling you it has stored a fault code.
You need a DICE to read it or a high end OBD scanner like the Autel 802
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Or just take it to a dealer for code readout.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Try it,but i doubt that anything which is not a Volvo scan tool will access ECC.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Autel 802.will read..
Acjlarsen
- Year and Model: 2000 volvo v70xc awd
I read another forum post that ECC error is often caused by grease getting splattered over the electrical board of the damper motor by the reduction gears inside its case. Where is the damper motor how do I get to it?
JRL
- Year and Model: Several
- Been thanked: 16 times
For Christ's sake, you can't rest them, that a hard fault/code, you have something wrong with the climate system, it needs to be read at Volvo with the old scanner.
Is there away to hand out Snickers bars via web post??
Op...raise the hood and check your cabin filter for crap grunge and leaves. If you get enough stuff in the recirc door the motor can't move it and you get the flashing lights.
You can also remove the glove box and confirm operation of the recirc door by watching the arm move.
