'98 V70 Water Leaking into Engine Bay
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Thank goodness the car isn't driveable right now anyway... it's got another leak.
It's been rainy here the past two days, and I had just put in new license plate lights, and I was going to test them. I opened the hood to jump the car, and I find water everywhere. Just looked like condensation from something, but it was definitely wet. The valve cover, spark plug cover, thermostat housing, radiator hose, brake booster, and battery were all wet. There is also and iridescent blue residue on the intercooler hose and strut tower, and green on the valve cover PCV hose. It won't come off, and it seems dry.
I left the hood up and ran some water on the windshield to see how it drained. There was nothing coming in, but there was water pouring out near the steering rack. I'm pretty sure that is a drain that's supposed to be there (if anyone knows, that would be appreciated). It's on the passenger side, just in front of the fire wall.
I thought it could be that seal along the cowl where the wipers are, but it doesn't seem to be coming in there. It is broken, but that doesn't seem to be a big problem. However, water is dripping down right onto the brake fluid reservoir and brake booster through that cowl.
Does anyone know where the leak is coming from, and how I can repair it? Should I run some RTV along the bottom of that cowl?
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
On the pictures it looks like water condensation rather than a leak, with most of it occurring on the metal srfaces. This can happen easily if the car has been sitting a long time in warm humid rainy weather.
I would blow the excessive moisture with some compressed air or even with a leaf blower before I start the engine, just for peace of mind.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
bmdubya1198
That's what I think, but the turbo/exhaust manifold shield collects a lot of water.
It has been VERY warm, humid, and rainy today. Hopefully that's why, because I've never seen it like that before. Absolutely disgusting weather, I can't wait for it to get back down to the 50s, where it's supposed to be this time of year.
regent
Post by regent »
Yea, I was thinking about this condensation again...
You may want to ensure averything is dry in the High Voltage Department before attempting to crank.
Not sure if you have the coil-over-plug arrangement, but if so, remove that cover and the coils and dry them up nicely. If you have a distributor, coil(s) and HV wires to each plug, then you want to dry up those components accordingly, even 'the goodies' inside the distributor cap. Moisture + oil and dust contamination will cause high voltage surface breakdown on the insulation and cost you more time and $$$ down the road
2015 BMW 335i
bmdubya1198
regent wrote:Yea, I was thinking about this condensation again...
Yeah, that's what I was a little concerned about. My distributor cap was a little damp.
gmh
Year and Model: 2016 XC60 T5
Has thanked: 28 times
Been thanked: 22 times
Post by gmh »
To the OP: There are drains for the cowl below the windshield on both sides of the engine. I've circled them in your photos. Each has a hose (about a foot long and 2in diameter) attached with a spring clip. Either remove the hoses, clean and replace or flush with water and compressed air. Once these are free, you'll have much less water in the engine compartment.
drivers side drain.jpg (102.43 KiB) Viewed 3311 times
pass side drain.jpg (98.96 KiB) Viewed 3311 times
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
bmdubya1198
Okay, those ARE drains. Thank you, and I'll take a look at those today!
Has thanked: 1613 times
Been thanked: 4078 times
Yuo will need to clean the holes up top, where the hoses attach, too. It looks like they are blocked.
I'm sure you condensation is waterproofing and getting splashed onto the engine.
