2010 S80 - Replacing part
erocki
Year and Model: s80 2010
Post by erocki »
Just a quick question...any major challenges for replacing the following? It seems pretty straight forward.
Frank Drebin
Year and Model: S80 T6 2000
Post by Frank Drebin »
Should be pretty straight forward. You'll need some type of counterhold to keep the bolt/ball steady while removing the nut - I'm guessing either torx on the inside end of the bolt, or "cutouts" for a wrench between the ball and the sway bar (there's probably a proper name for this, but I don't know what it's called).
You'll also need a crow bar to bend the sway bar down when you're installing a new end link.
