Thread to document the ME7 turbo car vacuum hoses.
First the sticker under the hood....FAIL....left over from 1998, I guess.
1999 V70 T5 comprehensive vacuum tube routing
- Has thanked: 1502 times
- Been thanked: 3813 times
Four connections on intake manifold
Left Banjo nut connects to PCV pipe and is hard connected with banjo bolt - runs to PTC nipple on air induction pipe to turbo
Centre Vacuum pipe connects to EVAP purge line, the other end connects to induction hose fitting above PTC nipple
Large Vacuum threaded fitting connects to brake booster line on rear of intake manifold (driver side)
Compressor Blowoff Valve fitting goes to lower fitting under PTC nipple
Turbo fittings
Boost pressure to 'red line' in Turbo Control Valve
Wastegate fitting goes to 'yellow line' on Turbo Control Valve
Blue dot line line goes to small barb fitting on intake manifold bhind brake booster connector
Turbo fittings
Corrected above - mixed up CBV and the Blue dot hose return on the Turbo Control Valve
I need to add pictures to this thread
S.Burton10
- Year and Model: 1999 V70 T5
Yes pictures, please!
Bumping this thread because bad info needs to be fixed
