how much power do i want this car to make?
biohazrd76
- Year and Model: 1997 850R
I admire this guy's engineering. Looks like something I would have done when I was 16. Rat rod esque whatever works
1997 850 R, black.
Ipd HD tcv, msd coil pack, ipd HD cbv, ipd stage 1 ecu flash, iridium plugs,heavy gauge plug wires, airbox cover delete, k&N cone filter directly before maf, ipd HD end links.
Graveyard: 1993 850 glt, NA 168 bhp,gold. Hit and run 2009 totaled
1995 850 Turbo, 222 bhp totaled
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I agree, I just don't see how it would add that much less heat to the intake. I'd love to see a dyno before and after installing the kit.matthew1 wrote:I'd do an IC before a RIP kit also.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Seaway
- Year and Model: 1998 V70 T5 Manual
Bigger intercooler = less heat? The Do88 website does a pretty comprehensive job of explaining it. http://www.do88.se/en/artiklar/volvo-85 ... ler-4.htmlmecheng wrote:I agree, I just don't see how it would add that much less heat to the intake. I'd love to see a dyno before and after installing the kit.matthew1 wrote:I'd do an IC before a RIP kit also.
- Has thanked: 317 times
- Been thanked: 531 times
I was going to ask that. What exactly is reverse intercooler piping (that is what everyone is referring to?) good for? It doesn't really make sense to me that it would give you any performance benefit.j-dawg wrote:It is really, really hard for me to believe the "RIP kit" does anything at all. There might be a cosmetic benefit if you like the way the shiny tubes look, but wrap some tinfoil around the existing ones and save yourself a couple hundo. Never seen one that wasn't absurdly priced.
biohazrd76
biohazrd76 wrote:A bit of info from the hvac industry: every time air must flow around a corner it's pressure is lessened. Therefore the mass air flow is less. So the less bends an intake has the more power it will make. Our stock ic piping is probably 14" longer than necessary. Will be putting the scan tool on my car today for first time, cel or MIL is burned out I'm guessing
1997 850 R, black.
biohazrd76
Turbocharging is all about shoving the coldest most dense charge of air into the manifold. This is the job of the Ic and it's maze of plumbing. Look at some Arab sand drag racing on you tube if you want to see some wild intercoolers and turbos. These guys are literally dumping buckets of ice into their intercoolers before a race!!!
1997 850 R, black.
Ah, that makes sense. Same idea as putting in a short ram intake, less piping.biohazrd76 wrote:biohazrd76 wrote:A bit of info from the hvac industry: every time air must flow around a corner it's pressure is lessened. Therefore the mass air flow is less. So the less bends an intake has the more power it will make. Our stock ic piping is probably 14" longer than necessary. Will be putting the scan tool on my car today for first time, cel or MIL is burned out I'm guessing
biohazrd76
Scan tool on last night, pulled codes:
1310 refer to svc manual
0305 cyl 5 misfire
0303 cyl3 misfire
0300 random multi cyl misfire
These codes were logged when I drove the car home from sellers house on 3 cyl. Got it home, plug wires were arcing to the block under the cover. Since have replaced most of ignition components and running smooth on all 5. Codes cleared 2 attempts . Will perform drive cycle test and re check for codes when my yard is dry enough to get the damn thing out!!
0305 cyl 5 misfire
0303 cyl3 misfire
1997 850 R, black.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
The RIP kit effect is probably placebo. When you have feet upon feet upon feet of intake piping, the several inches you chop out with the fancy tubing is negligible. If it isn't, the effect cannot be worth anywhere near the cost when the same money gets you an ECU tune.
My two cents.
My two cents.
- 18 Replies
- 11017 Views
Last post by erikv11
- 382 Views
Last post by hausmeister
- 10 Replies
- 1660 Views
Last post by MrAl
- 909 Views
Last post by Stoffelmans
- 1960 Views
Last post by JimBee
