Mass oil leak-v70 2003 2.4t
Googs1080
Year and Model: V70 2003
Post by Googs1080 »
While driving, the car sprays out all its oil on the passenger side of the engine compartment. Any ideas where to start looking or if worth diving in to try and fix? While not primary leak, it appears oil also was forced out of the fill cap. No leaking when car is off. How do i even look to see where oil coming from.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
You have a clogged PCV system because of bad oil change history. $350 in parts and about 8 hours of labor. Plus the seals and most likely t-belt kit.
Been thanked: 4067 times
IF the pressure gets high enough, you start to pop seals out and spray oil everywhere.
While I know it looks awful, if you had a leak under the car, which isnt nearly as messy, it would cost you 1000-1500 to have the engine removed to fix.
Googs1080
Post by Googs1080 »
Thanks for suggestions of the issue! Y'all were spot on!!! The cam seal was popped off. Put a rubber glove over the oil filler and it blew the glove up. Pcv must be clogged and thus the pressure popped the cam seal off. I took cover off and could watch the oil spit out. Wish i could figure out how to add pics here
Just go to full editor, manage attachments, and then add photos to your posts
Googs1080
Post by Googs1080 »
Here were the clogged ports!  Wow
Guess gotta chamge the pcv every 100k regardless. Wow
That's a severely oil change neglected engine. The PCV on P2s doesn't clog like P80s...mine was clear at 175k and didn't really need changing.
Googs1080
Post by Googs1080 »
So angry at volvo dealership that was supposedly doimg the oil changes. After my mechanic did the camp silver repairs car drove for a day and then we got engine can position sensor error. Mechanic said it's a special tool to adjust the timing he doesn't have Wife said the car just made a noise and won't go over 30 without loud ticking now. Is this a Volvo special kind of timing issue or could I have a wire or something going loose from the repairs that were done
Googs1080
Post by Googs1080 »
Sorry typo. Meant to say cmp seal repair. Error code came back crank or cam position sensor
With that much sludge in the motor the solenoid for the variable valve timing are almost certainly plugged. Try to get the actual codes, like P1234 , which are much more useful than the descriptions.
I think I would drop,the oil pan on this to clean out sludge. You also have to make sure the passage is cleaned out in the block with repeated insertions of tube or wire. There are some pictures of this on MVS
