Have any of you used a Nissens A/C evaporator on a P80? If so what is your opinion compared to using OE?
A few years ago I used an aftermarket evaporator on a 93 850 and had a nightmare with poor fit and took days longer to install due to miss-shaped connector cones in the engine bay. Eventually had to file them down and re-shape to get them to fit. Can't remember the brand though.
Thoughts and any other brand suggestions that you have used and been happy with.
I am considering pulling the dash for repairs, so may take the opportunity to tackle this while in there.
P80 Nissens A/C Evaporator
- Has thanked: 2209 times
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
Don´t know, but if I were to pull the evap (still hoping I don´t have to this year) I´d go with Volvo/OEM because this is nothing I´d like to do again. Kinda like buying an aftermarket RMS. Just my 0.02$
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 1611 times
- Been thanked: 4072 times
I'll look and see what I used on my 1999. I think I used OEM but paperwork will tell.
I bought it from eEuro, part number 918739 back in 2013-03
That SKU is showing as a Rein unit, today. Its about 90 USD
Fitment was easy, I recall having to bend the aluminum hoses slightly to align the AC coupling. I have not added any fill to my AC in three years, so everything sealed tight.
Thanks for getting back to me.
I can't now recall the brand I used on the 93 850. It was a nightmare, and I'm sure I bought it from FCP. Part worked fine eventually, but it took a lot out of me, having to bend the pipes and file down the end flares so the 'o' snap could connect as they couldn't get over the flare ends as they were too big.
That is the reason for my question as to brands as I also only want to do the job once, but also having a part I don't have to fight to fit and works well is important!
I am a confessed hoarder, but mostly only with OE parts, but as these are getting harder to find, I worry about waiting to buy a part at a good price to store away, only to find that when I get around to fitting it there is a problem!
Thanks again for your help!
Any other inputs on brand quality of this part is also appreciated!
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
The sled has had a tiny evaporator leak for years. My heart sank! Thought Volvo had fixed this issue before my 98. Fortunately, it only requires about half a can once a year or so. My dash doesn't squeek so that's not an incentive. I just keep topping it up and it continues to cool well. Not sure how long I'll be able to do this however. So far, I've been quite lucky.
M1 10W-30 HM
M1 10W-30 HM
Yes, I agree, don't plan to, or want to do this, but when the squeeking dash gets to be too much it will come out for my good spare one, and I'd do the evaporator and clean out the heating system more thoroughly than I can when it is in place.
Dash out on the 1999 wasn't too bad, I have to say. I think it was about 2-3 hours, including bagging and tagging parts
kaneelschep
- Year and Model: '96 850 2liter t5
Nissens ia a good brand. My 500sec has a nissens radiator. Works and fits perfect. Its a very commonly sold brand here. See it a lot. No reason not to get it.
- 13 Replies
- 4329 Views
Last post by BEJinFbk
- 1032 Views
Last post by bmdubya1198
- 751 Views
Last post by precopster
- 15 Replies
- 2836 Views
Last post by cuhfs
- 31 Replies
- 6133 Views
Last post by aeg
