1999 S70 P0328 Knock Sensor
asummers
Year and Model: many
Post by asummers »
My S70, non-turbo, automatic has been having some stalling/dying issues lately. When driving it will loose power and sometimes die, put it up in neutral and start it and rev it a few times, and it gets going again. I haven't had the check engine light come on at all during this. But, I hooked my code scanner up and there are no stored codes. But, when the engine is running it reads this code: P0328 KNOCK SENSOR 1 CKT HIGH LIMIT BANK 1 OR SINGLE SENSOR. But, only when the car is running. Could the knock sensor having issues cause it to stall and die? Thanks.
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Don't think so, the knock sensor only helps adjusting the timing so as the engine doesn't ping. Is the engine pinging while driving near a wall with open window?
Rather, the front O2 sensor could be busted, I'd start looking at that.
