Just changed pnp in a 2000 v70
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Could be- If you haven't buttoned her down completely yet, take it off- spray with a good cleaner (like a MAF cleaner) and use some dielectric grease in the fittings and work it off and on a few times and see if this clears things up. if not, then you've hit something- maybe even a fuse went. My luck has been that things go wrong in (at least) pairs with these cars and much of the time they seem completely unrelated.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
I highly recommend Midwest ABS but I would check with forum member Matty Moo first. He runs Midwest ABS and can likely tell you right away if your symptoms match those of a bad ABS module.
- 1963 Views
- 810 Views
Last post by Ozark Lee
- 1074 Views
Last post by precopster
- 809 Views
Last post by polskamafia mjl
- 13 Replies
- 2670 Views
Last post by stephansvolvo
