A/c compressor only kicks on with bypassing main fuse in fuse box..
Has thanked: 1609 times
Been thanked: 4065 times
There are a set of relays under the fuses on your 1999 - you have to undo the Torx screws and lift the main fuse panel to access.
Been thanked: 504 times
Post by cn90 »
As mentioned, check the wiring between the AC Relay and the compressor.
