I need some help. Volvo 1999 V70, runs great. But I can not get the sucker to pass emissions, I have a check engine light and the code P1073. I can not find anywhere what that code means at all.
It is also the code that is failing me at emissions. When I clear the code, it will come right back in about 20 seconds.
1999 OBD code P1073 ECM1100. Outside air temp sensor Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Where in the link did you read "secondary maf sensor"
Maf on your car is attached on airbox just like on all other models.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 316 times
- Been thanked: 531 times
Probably a bad MAF sensor. Which seems odd to me since you say the car is running fine.
It does. All you have to do most of the time... it'll avoid lots of threads asking about codes!crlande wrote:http://www.obd-codes.com/sitemap.php
Save the link, it comes in handy.
In this case the site was wrong. Since the p1073 was in the custom manufacturer code range.
For a 1999 Volvo it's the external air temperature sensor. I broke down and narrowed a laptop with the Volvo software on it.
What was the ECM code called off with VIDA?
- 569 Views
Last post by JimBee
- 3276 Views
Last post by Sommerfeldt
- 5133 Views
Last post by Raindog92
- 9 Replies
- 2059 Views
Last post by misha
- 731 Views
Last post by ja564rm80
