Injector o-rings in the kit
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
FCP's extended service tune up kit includes a set of upper and lower injector o-rings.
Those are the ones where you take the injector apart, replace the rings, and put it back together, right?
Is this something I should be doing preemptively? The car's got 200+ish on it, long-dead odometer.
5 others that came and went
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Those o-rings should be just upper and lower seals...black rubber o-rings.
The ones which require taking apart of injector are the hard spacers...yellow(or light brown) ones.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
If you're pulling old injectors, you should buy the kit preemptively. You will probably break one of the pintle caps.
While you're at it, you might as well replace the filters too.
kcodyjr
Post by kcodyjr »
I'm going to have the rail off for a PCV job, at the same time as a comprehensive tune-up.
I wouldn't have suspected an injector issue, and wouldn't touch them, except the tune-up kit came with the o-rings, so somebody must have thought it was a good idea.
I don't see an actual injector rebuild kit on FCP's site, but I do see two different types of seals besides the o-rings. Those are the internal ones, then? I've never had an injector apart.
So, point blank: what preventive maintenance should I be doing to the injectors in this circumstance? Should I be tearing them apart just because they gotta suck by 200K? Should I leave them be but be prepared for damage taking them out?
beigg
Year and Model: 850 97
Post by beigg »
Ya might consider upgrading to a slightly higher rated set of injectors at this time. Minimal bump in power, but the age combined with amount of use has to be considered, especially with today's fuel qualities being pushed through them.
Grabbing the higher flow rated ones from a salvage yard volvo to have rebuilt might be the most economical way about it.
ugh smh 850 Turbo fridge
misha
Post by misha »
There is NO gain with larger injectors without ecu remaping.Larger injectors can only make problems on stock ecu.
You can remove the old ones and send them to professional ultrasonic cleaning.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
kcodyjr wrote:So, point blank: what preventive maintenance should I be doing to the injectors in this circumstance? Should I be tearing them apart just because they gotta suck by 200K? Should I leave them be but be prepared for damage taking them out?
I'll be doing this service as well. More about it on this thread: https://www.matthewsvolvosite.com/forums ... =5&t=20042
M1 10W-30 HM
j-dawg
Post by j-dawg »
kcodyjr wrote: So, point blank: what preventive maintenance should I be doing to the injectors in this circumstance? Should I be tearing them apart just because they gotta suck by 200K? Should I leave them be but be prepared for damage taking them out?
If you are pulling the rail, see what condition the o-rings and pintle caps are in. You can decide for yourself at that point if you want to replace them. (Obviously if you break any of the pintle caps you'll have to replace those.)
I would recommend replacing the pintle caps and o-rings, just because it's an easy job with cheap parts and you're already in there. Chances are you will have to replace one or two. The filter baskets I replaced, but it took enough body strength that I was afraid for the injector. The old ones didn't look bad after 240k, so I probably would skip that.
Not sure if the 850 has a fuel pressure damper, but my V70's damper's o-ring was in sorta iffy shape when it came out.
kcodyjr
Post by kcodyjr »
If the pintle caps are so prone to breaking, I'd rather just plan on replacing them.
I don't see 'em on FCP. Got a source? Tell me I don't have to go crawling through a junkyard...
beigg
Post by beigg »
misha wrote:There is NO gain with larger injectors without ecu remaping.Larger injectors can only make problems on stock ecu.
Historical threads posted have suggested otherwise.
