Serpentine belt does not fit Topic is solved
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
A while back (Jan 2016) one of the vendors shipped me a Contitech belt that was labeled on the outer package as a 1743 but the belt inside was labeled 1741. It wouldn't fit on. I asked the vendor about it and they told me that they had received a batch of belts with the wrong size but in the right package.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I have a good video that shows how to route it both ways.
rspi
Post by rspi »
Serpentine belt routing on the Volvo 850, S70, V7…:
AlanKot
Year and Model: 1998
Post by AlanKot »
That's the thing - I've done belts before (mostly on my Land Rover) and its always been pretty straightforward. I look at all of the pulleys and the belt is sitting on all of them properly and the tensioner is pulled back and locked with a pin (I tried going past that point and it moves only a little bit, not enough to make a huge difference). I am going to the the wheel off and access the crank to make sure its sitting on it properly. Btw I've tried going onto the idler pulley last - same thing, about an inch too short.
rspi
Post by rspi »
Did you watch the video?
AlanKot
Post by AlanKot »
I watched the video and thats exactly how I route it. Going to go after it again in a bit. Wish me luck!
Been thanked: 4065 times
How much the idler changes the belt path is a function of how big a sector it subtends, but small changes are important! Get every last bit of tension on that idler.
Has thanked: 311 times
Been thanked: 817 times
jreed wrote:A while back (Jan 2016) one of the vendors shipped me a Contitech belt that was labeled on the outer package as a 1743 but the belt inside was labeled 1741. It wouldn't fit on. I asked the vendor about it and they told me that they had received a batch of belts with the wrong size but in the right package.
This is an informative post. Did you eyeball that the belt itself says 1743 on it?
How many MVSers does it take to change a serp belt ... :)
AlanKot
Post by AlanKot »
I don't believe this! The belt says 1740 but the package says 1743!
:evil: :evil: :evil: :evil:
