Hoses (Radiator, Heater): Rubber vs Silicone
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
precopster wrote:I also fitted the MOFE set with Samco logo for the 98V70R in blue. They were a PITA to fit however they look great to me.
I like them!
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
I bought my hoses from Stylin' Motors back in '06. I got the clamps they offered at the same time. They're 10 years old and still look and work great
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
abscate wrote:I like closed band clamps in stainless steel Marco. You have to get them quite tight, but it's ok if they seep a bit, you just tighten them a bit more. Sometimes a couple of cycles will stop the seeping without tightening the clamp. ( a master plumber taught me this trick on plumbing....a drip on a fitting less than 10 per minute will self heal without over tightening Fitting)
Thanks, abscate!
I like these clamps, too. I'll look around and see what I find online. I know you can get clamps for next to nothing at any neighborhood auto parts store. But this really is a place not to skimp. Clamps should last the life of the car! Thanks everyone for the pictures of your clamps, gosh, they're beautiful! I'll post up the results, pictures, and prices in case anyone else is as interested in clamps as I am!
Great tip about the seeping and self-tightening fittings! Especially for anyone thinking about over-tightening a clamp on the plastic inlet of a radiator! :shock:
Retired:
2015 Volvo S60, T5, 85K
theWIFES_S70
I have found these hoses on eBay and am wondering if anyone on here has installed them. Is it as simple as carefully removing the old heater core hoses and clamping these over the metal outlets? It says that these are only for Turbos... But aren't the heater core hoses the same on Turbos and N/As?
http://www.ebay.com/itm/Volvo-850-S70-V ... HA&vxp=mtr
oh man, IPD has them for cheaper...
https://www.ipdusa.com/products/12034/1 ... swodHPILCA
eEuroparts is carrying them, too... probably the best bet for folks on the east coast
https://www.eeuroparts.com/Parts/67909/ ... DQodRloIKA
Retired:
bmdubya1198
I remember looking up the heater hoses for my cousin's T5, and I think the turbo heater hoses are different. I think they're routed a little differently because of the placement of the turbo.
Has thanked: 311 times
Been thanked: 817 times
Yep, turbo and NA heater hoses have different shapes, because the turbo is right there near the firewall.
theWIFES_S70
Oh wow... I didn't know.
98 S70 N/A heater hoses:
98 S70 T5 heater hoses:
The distance looks a little similar, no?
Retired:
bmdubya1198
Distance look similar... main difference is the hard line. Honestly you might be able to fit the turbo lines on an N/A, but you might have tighter bends in the hose, which could kink it and restrict coolant flow.
Has thanked: 1611 times
Been thanked: 4071 times
Is that install really that simple? You need to block the firewall hole when done....???
bmdubya1198
abscate wrote: 03 May 2017, 02:45 Is that install really that simple? You need to block the firewall hole when done....???
Replacement was pretty easy on my cousin's S70. It took a little bit of moving things around, but it was pretty straightforward. Not much leakage surprisingly.
