Brake fluid leak
tom4342
Year and Model: 1998 v70 awd
Brake fluid leak
Post by tom4342 »
I noticed fluid leaking around the plug at the bottom of the fluid reservoir is there a gasket that can be replaced or am I looking at replacing the module?The plugin on top leaking around that pretty good
Tom Hood
Been thanked: 474 times
Post by cn90 »
Search for the thread that someone wrote on Master Cylinder DIY recently.
Has thanked: 1507 times
Been thanked: 3825 times
Probably best to get that from a junkyard if you can find at the usual suspects...
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 36 times
Post by theWIFES_S70 »
tom4342 wrote: 14 May 2017, 19:43 brake.jpgI noticed fluid leaking around the plug at the bottom of the fluid reservoir is there a gasket that can be replaced or am I looking at replacing the module?The plugin on top leaking around that pretty good
Hi, are you talking about the brake pressure sensor? If so, yes, there's an o-ring there. I don't believe that sensor is available new anymore. So you would have to get one from a junkyard if you want to replace it. I'm sure just the o-ring goes bad on that. Make sure you have a bunch of sizes on hand because you don't want your brake master cylinder to dry out because you took that switch off and drove around for hours (days...) looking for a suitable o-ring!
Robert Spinner has a video on taking that thing out https://www.youtube.com/watch?v=rhDAgSJmjAc
There are also o-rings around the base of the brake fluid reservoir.
What I'd do to try to isolate your drip is to really stick your finger with a napkin on it and try and touch where exactly you're leaking from. Touch different parts throughout and see what you find.
I don't know how to fix that cap... I don't think mine has ever been dry on the outside...
Retired:
2015 Volvo S60, T5, 85K
tom4342
Post by tom4342 »
Tom Hood
tom4342
Post by tom4342 »
the switch is wet and dripping with fluid that sucks it's no longer available hopefully that's all it is the O ring.
Tom Hood
theWIFES_S70
Make sure you aren't leaking from above. It's really hard to accurately pinpoint these leaks (hence using paper to see what's wet and what isn't). I have come to believe most of these leaks are probably master cylinder leaks... And man, is that a doozy... Good luck.
Retired:
tom4342
Post by tom4342 »
At least I can get the master cylinder
Tom Hood
tom4342
Post by tom4342 »
Definitely the switch leaking go figure I wonder if this is why the check engine light is staying on? I ran my scanner and showed no codes and the brake light is staying on even though I filled the reservoir.
Tom Hood
theWIFES_S70
It's definitely connected to something so I would imagine it could trip a check engine light.
I might try to pick up some o-rings, take it out the sensor and clean the electrodes with electric parts cleaner and put on a new o-ring on it and hope it doesn't leak...
Seems like the used MCs on eBay come with the sensor. So maybe you want to go that route...
http://www.ebay.com/itm/99-00-98-volvo- ... IA&vxp=mtr
Make sure you find some o-rings that are compatible with brake fluid...
http://forums.mtbr.com/downhill-freerid ... 13710.html
The again, Harbor Freight says these nitrile o-rings are compatible with hydraulic fluid... https://www.harborfreight.com/225-piece ... 67677.html
You're looking for something you could roll onto something smaller than a pencil.
Good luck!
Retired:
