97 850 replaced pcv and started motor
And the car throttles up to 4k on the tack and the up arrow came on. This wasn't happening before kinda stumped. When I reset with the ignition it will idle around 900 for about 30 seconds the up arrow comes on and motor climbs to 1100 rpm
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Most likely a vacuum leak somewhere. My brother did a PCV job and it idled horribly afterward. We couldn't figure it out and his shop smoked it. Somehow he'd warped the mating surface on his intake manifold. Remedy was two gaskets and orange RTV. You might want to take off that brake booster line, smoke a cigarette, and get some smoke in there to see if you need to pull that manifold off again. Is this an N/A or a Turbo?
Starter is probably not this. As the starter only engages the flywheel when cranking and then just retracts, like a turtle into his shell, awaiting the next crank.
Retired:
2015 Volvo S60, T5, 85K
- cmblackburn
- Year and Model: 1998 S70 T5M
- Been thanked: 7 times
Sounds exactly like you didn't plug the throttle position sensor back in.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
- Has thanked: 312 times
- Been thanked: 818 times
Ding ding ding!cmblackburn wrote: 30 Jun 2017, 08:06 Sounds exactly like you didn't plug the throttle position sensor back in.
thanks thought i was going crazy. Hey give me a little slack first time punishing myself , but i still want to see her ride. Sorry about starter was punching that in on my phone.It is a N/A but the motor sounds sweet
- Has thanked: 2211 times
if the car is now running well, well done on completing this first challenge of old Volvo ownership! We have all done the senior moment (some us more than others!), and forgotten to re-fit a connector or 2. Now go and enjoy!
- theWIFES_S70
Jaybar, you'll find the fellas on here are almost always spot on. Always start with the simple stuff first. Hope you have a nice drive planned this weekend!
Retired:
- Has thanked: 1611 times
- Been thanked: 4075 times
24 minutes to a diagnosis...awesomecmblackburn wrote: 30 Jun 2017, 08:06 Sounds exactly like you didn't plug the throttle position sensor back in.
Space reserved for the MVS Swedish horns....
- 350 Views
Last post by Jaybar
- 1546 Views
Last post by RickHaleParker
- 1001 Views
Last post by Series2a
- 13 Replies
- 2377 Views
Last post by Sommerfeldt
- 16 Replies
- 3562 Views
Last post by pred
