Firing Order
mnmk
Year and Model: V70 2004
Post by mnmk »
Hello.
I have a 2004 V70 2.4l B5244S engine.
Does anyone know the firing order of the cylinders?
I have a cylinder #3 misfire and trying to locate the correct one.
Thanks for the help.
Been thanked: 4069 times
It doesn't matter which end you count from, # 3 is in the middle
But you start with the front of the engine, which is where the timing belt and serpentine belt are ( being non drive side specific) and label that cylinder Number 1 and on from there.
Warning...at least one manual, the Haynes I believe, as the firing order wrong in print.
Most of us , including me, with P2 coil on plug ignition have no clue what our firing order is, we leave that to the ECU
mnmk
Post by mnmk »
Thanks for the information!
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
abscate wrote: 04 Jul 2017, 05:44 It doesn't matter which end you count from, # 3 is in the middle
Is firing order the same as linear cylinder numbers.
They don't fire in a linear fashion, or do they? Surely that would cause whipping in the crankshaft.
I suppose swapping two around would indicate which one is which.
I believe all these white block Volvo's fire 1-2-4-5-3
