Well I figured I'd continue my thread posting streak and ask about another one of my annoying bugs...
Sometimes when I have my headlights or parking lights on and I flick on my turn signal in either direction, the bulb failure light will flash in unison with the turn signal. However this isn't every time, and usually the light will only flash really quickly at the beginning of the turn signal flash and fade out. And today, I noticed that when I turned on the hazards, the back light behind the headlight knob parking light symbol was flashing brighter with the hazards. Pretty crazy.
Now, I think whatever the issue is, it's definitely related to one of the turn signals' wiring, BUT, I wanted to ask first to see if maybe this had anything to do with the flasher relay built into the switch. It's incredibly odd to me that the headlight knob would be flashing though. Where would there even be a common circuit?
I'll note as well that I have wired in the fender marker lights, but I don't think that would be a problem because the wires are soldered very nicely and wrapped securely. I also tapped into the dimmer switch in the dash to supply voltage to my boost gauge back light, and again, it's soldered and wrapped up.
Bulb Failure Light Flashes With Turn Signals '98 V70
- Has thanked: 316 times
- Been thanked: 531 times
- Has thanked: 2202 times
Try swapping the bulbs out for the flasher units (front and back) as a bad bulb can cause this but still works. Also make sure the contacts on the bulb holders are clean and any related ground wires are onto clean surfaces.
Thanks, I'll clean all the contacts. Didn't think the bulbs could be an issue being that they all work perfectly fine, but who knows. If cleaning all the contacts doesn't work, it'd be worth a shot.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Wow...I see my post never made it!
I recall something about a MVS server issue..'not responding'.
Bummer......
Bummer......
M1 10W-30 HM
M1 10W-30 HM
You keep having problems with that! Tell Matt to fix it!sleddriver wrote: 14 Sep 2017, 12:42 Wow...I see my post never made it!
Bummer......
- sleddriver
bmdubya1198 wrote: 14 Sep 2017, 15:56You keep having problems with that! Tell Matt to fix it!sleddriver wrote: 14 Sep 2017, 12:42 Wow...I see my post never made it!
Bummer......
M1 10W-30 HM
M1 10W-30 HM
I've had that problem a couple times in the past few months. Strange.
- Been thanked: 4068 times
My server crashes report P0455......
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Cloud flare occasionally is the issue - even though they claim the remote host (server) isn't responding. Occasionally this happens due to a server being under a big load - such as site maintenance of databases or backups.
You better hope that P0455 stays on your screen and my car doesn't catch it =p
P0455 has been infecting my car for the past few months. I'm basically immune!
- 626 Views
Last post by bmdubya1198
- 1973 Views
Last post by Dieterly
- 4142 Views
Last post by silentcircuit
- 1771 Views
- 4874 Views
Last post by adrian22
