Just a quick report that this puppy weighed in at 76.5lbs. easily removed on a floor jack, single handed, dropped, and leg lifted onto a furniture dolly for moving, solomente
Local corrections for G and also reduced mass were ignored in this measurement
P80 P2 M56 transmission mass 75.6 lbs
- Been thanked: 4068 times
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Dropping it down it weighs 75lbs. Going up for installation while you are on the ground looking up... and positioning it it starts feels like 150lbs. That's why the jacks and the come-along-strap are necessary. May need a second helper/set of hands for install positioning. I found it helpful... so I used a teenager that's on the payroll already.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Yeah, it's a two person reinstall....teen already recruited
I'll put a piece of lumber and a strap to help position from up top too, so I can swing it in the breeze and allow angular adjustment to the engine.
Thanks, Rick!!
Thanks, Rick!!
JRL
- Year and Model: Several
- Been thanked: 16 times
2 person. Someone needs to guide it back in
Thanks Jim. It would be really difficult to get this aligned and back in solo, indeed, unless you had that fancy articulated $8000 gold plated Volvo jig
01_Nautic_V70
- Year and Model: 2008 XC90 V8
- Been thanked: 8 times
I've done the automatic at 300 pounds twice with a floor jack and ratchet strap. Simple machines and patience go a long way.
Ah grasshopper. Automatic not require gearbox shaft to be precisely aligned to clutch and bearing in crankshaft
01_Nautic_V70
Ah, I see abscate-san.abscate wrote: 27 Sep 2017, 01:44 Ah grasshopper. Automatic not require gearbox shaft to be precisely aligned to clutch and bearing in crankshaft
You enlighten me, Nautic-sensei
- 457 Views
Last post by foggydogg
- 2061 Views
- 1319 Views
- 504 Views
Last post by VPrints
- 158 Views
Last post by darylrobert
