Chemical burning smell Topic is solved
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Post by jtp »
Just got home and upon getting out of the car there was a horrible chemical burning smell. It went away very quickly once I was parked with the car off.
When I left for home I made a three point turn and there was a loud creaking/popping sound when the wheel was to the extreme right. Checked the PS fluid and everything else just now and all levels appear good.
I was thinking air in the PS lines given I replaced the Resevoir the other day. But I’ve driven 100+ miles since then and this was the first weird steering symptom.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
There are a number of fluids and compounds that each make different smells. Unfortunately smells can be highly subjective...
Does it smell sweet? Does it smell corrosive/acidic? Does it smell oily?
Does it smell like clutch material? If so, check for a stuck/frozen brake caliper if you have an automatic.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Sweet smell - Antifreeze
Rotten eggs/Somebody farted - Battery acid (hydrogen sulfide).
Burning Rubber - Belts.
Oil - self explanatory.
Dinner burnt - Could be a lot of things.
Active
Past
jtp
Post by jtp »
It definitely wasn’t a sweet coolant smell, very acidic. Gonna get it into the shop today, everything looks good right now leaving the house
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
If it's a sharp acrid smell, be careful as that can be burning wires/electrical smoke or fire. I'd check all fuses to be safe. Could be something like power steering fluid leaking onto something hot though which may cause a bad smell too.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
RickHaleParker
very acidic
Battery and charging system.
Active
Past
Been thanked: 4065 times
Oil leak onto exhaust manifold will make your eyes hurt.
When the battery or alternator fail hard enough to smell, it's usually visible boiling and acid venting.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
RickHaleParker wrote: 15 Jan 2018, 06:27 very acidic
I'd concur
The time I got this smell I just had installed a flexible downpipe and secured it with a 'high heat' J-B weld stuff. Drove it straight to the garage to have the stuff removed and the pipe welded
jtp
Post by jtp »
I drove it into work (I work at a VW dealership) and gave it to the top guy, not a Volvo guy but he's really good. You'd think your car gets priority if you work at a shop but on a busy day like today thats not really how it goes. Hes gonna get it in this afternoon so Ill report back.
Trying to get this thing fixed up would be a lot easier if it stopped breaking :roll:
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
I’ve heard Norwegians are flocking in to DC with burned kippered herrings, are you downwind?
