Didn't notate hydraulic lifters position
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
It is worse than that it doesn't come back up
Replace it.
What does the other 19 look like?
Active
Past
KevinBug
Year and Model: 99 S70
Post by KevinBug »
They are not nearly as bad some are kinda like video only two are real hard so soft is.not.good?
KevinBug
Post by KevinBug »
Have over half like that last one
KevinBug
Post by KevinBug »
Should I replace all of them I saw the whole 20 for 192, supposed to be genuine Volvo from europarts
KevinBug
Post by KevinBug »
I don't want to have to go back to replace a CPL lifters
RickHaleParker
1. Hard - good
2. Gives some - Marginal.
3. Soft - failed.
From what you saying above I count 2 good, 17 Marginal 1 failed. If that was my score, I would do a new set and be done with it. You going to do the valve stem seals and lap the valves while you got it all open?
Active
Past
KevinBug
Post by KevinBug »
I already did valve stems lap? Head gasket replaced cleaned heads block new starer new water pump new pcv system, new crank seals, new tensioner timing belt, new timing belt, new oil pan. Might as well get new lifters!!!! Lol now all put back together to the cams
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I always thought that soft meant they had air in them; they are not a sealed unit and will refill with 100% oil in their own in time.
I once rebuilt a 10 valve Volvo 850 head and the lifters ticked away for more than 2 weeks until they totally filled. Kept the car for a year and the noise didn't return.
RickHaleParker
They do have check valves in them. They are suppose to fill and hold oil even when the engine is off. In the video you see oil oozing out on the third one when he presses down, that is a failed check valve. The check valves are what keep the valve train from chattering every time you start the engine. They also regulate the adjustment. The hard one will regulate well. The Semi-soft ones will do OK. The soft ones that spring back up would work but barely.
1. The hard one are holding oil at the right pressure.
2. The Semi-soft are holding pressure but not at the right pressure.
3. The soft ones are holding very little pressure.
#2 and #3 will pump up when the engine is running but they will chatter until they do.
The real bad one that Kevin Bug has is completely collapsed, it is not holding pressure at all and will not pump up when the engine is running because it cannot hold any pressure.
Active
Past
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
KevinBug wrote: 16 Jan 2018, 19:08 Should I replace all of them I saw the whole 20 for 192, supposed to be genuine Volvo from europarts
FCPeuro has the same kit for less than $190 and you get lifetime warranty.
https://www.fcpeuro.com/products/volvo- ... v70-270866
