Hi, I'm looking for the paint code for my 2011 Volvo C30. I've searched inside both doors. If it's in the engine compartment or on the firewall, it's certainly not in an easily noticeable place because I've looked and looked. I've read that it's on the rear of the passenger side 'B' pillar. It's not inside that door. Do I have to remove the trim in the backseat to see it? The label inside the driver's door doesn't give any paint code information or anything like that.
I've tried looking it up by using my Chinese VIDA and reading it that way, but it won't read the "vehicle details" when I click on that.
That's frustrating because it actually has a space for vehicle color code, but it remains blank as VIDA says, "No connection with QW90 available. Please contact your local Helpdesk. No connection with PIE available." So I've had no luck there.
I'd appreciate any help if anyone else has encountered this.
Thanks!
2011 C30 product plate/paint code location?
- RickHaleParker
- Been thanked: 978 times
It should be on the passenger's B pillar.
Active
Past
Past
- RickHaleParker
I can't imagine the previous owner taking it off.
My best guess is, its has been in a Body Shop.
Monitors don't replicate colors dependably. On my monitor, it looks like your paint is one of three colors.
Paint code 426 Mystic Silver Metallic.
Paint code 477 Electric Silver Metallic.
Paint code 455 Titanium Gray Pearl.
A paint store or a paint shop could narrow it down with a Spectrophotometer.
Did you install the patch after you installed Vida?
Active
Past
Past
greentea
- Year and Model: 2009 S40
- Has thanked: 9 times
I did install the VIDA patch when I initially got it up and running. I had to do another patch back in January to make it work in 2018. I don't know if that last one would have affected the earlier one.
I'm actually having the paint touched up. My painter thinks it's 426, but I was wanting to find that plate to confirm. I'm not sure if any of the paint stores around here would have a spectrophotometer, but it's worth a call to see. Thanks for the tip.
- RickHaleParker
Go here
1. Patches for Vida 2012, 2013 and 2014.
2. Instructions and files for installing 2014D on Windows 10.
3. Links to instructions for moving Vida over to Google Chrome. Solves a lot of issues in Windows 7.
4. How to get Vida 2014D working in Windows 7 with IE11 and .net framework 4.X installed.
5. Other tweaks.
5. Other tweaks.
Active
Past
Past
greentea
VIDA's diagnostic section and everything else seems to work, just not the "vehicle details" section, which I'm not sure I've ever used on the many Volvos I've had this VIDA hooked up to, so I don't know if it's ever worked.
- RickHaleParker
QW90 and PIE are external databases. Unless you pay you out of the nose, you don't have access.
Active
Past
Past
greentea
I see. Thanks.RickHaleParker wrote: 26 Mar 2018, 13:06 QW90 and PIE are external databases. Unless you pay you out of the nose, you don't have access.
- 14 Replies
- 4513 Views
Last post by schoolhousejulie
- 950 Views
- 662 Views
Last post by MoVolvos
- 1921 Views
Last post by RayF
- 1943 Views
Last post by mf70
