Adding fog lights to a 2002 V40
volvobydefault
Year and Model: 2002 V40
Post by volvobydefault »
I've got a 2002 V40 that I'd like to add fog lights too. The car has a factory fog light switch that controls the rear fog lights, but it has no front fog lights.
I've been looking for information about adding a set of fog lights and have not found anything. I haven't started looking at wiring yet either. I'm hoping I can pull a set of factory lights from another v40 and that a wiring harness might already be in place.
Has anybody done this before, and does anybody have a link to a write-up? Thanks!
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
I have no experience adding fog lights, but I suspect the car is already wired for them.
Pull the covers in the lower bumper and see if there are wire connectors there.
Also, pull the plastic dashboard knock-outs that are near the rear fog switches and see if there are plugs there.
There may be an additional relay or fuse to utilize.
'84 Prelude
'06 MPV
'13 Ford Focus SE
jlarosa
Year and Model: 2003 s40
Post by jlarosa »
I actually installed fog lights on my 2003 volvo s40, and replaced the light switch box in the dash with one that has the Front Fog Light button... no work :(. Right now i haven't had a chance to do much, but i am going to make my own switch and use a relay and a resistor to make the connection to the fog lights from a 12v source. I'll figure it out and post anything i can on here.
volvobydefault
When you installed the fog lights, did you find any unused plugs for them as part of the factory harness?
