2005 XC90 Died on hwy, fuel pump?
Been thanked: 504 times
Post by cn90 »
- Junkyard PEM is about $10-$15.
- Ebay PEM is about $45-$50.
Swap a used a known good PEM and see what happens...
Skenda02
Year and Model: 2005
Post by Skenda02 »
Pulled FPS out and it is pretty corroded even at the plug and around the plug is cracked. Bosch 8629164, having hard time finding one that I'm not getting taped for on price. Any way to find aftermarket compatible? Bosch doesn't make this one anymore.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Fcp , Ipd any FPS for turbo XC90 will do https://www.fcpeuro.com/products/volvo- ... 10#fitment
Has thanked: 1611 times
Been thanked: 4074 times
Check your PEM part number and see if you can get a spare from a PnP to try
I can loan you my spare for trial if it fits, if you search your part number in the P2 forum you should find the thread on troubleshooting.
Skenda02
Post by Skenda02 »
Replaced Fuel Pressure Module, car started right up but now check engine light on. Code came up fuel pressure too high at rail. Tested and came up between 85 and 90
Skenda02
Post by Skenda02 »
Between 85 and 90
oragex
Post by oragex »
That's very high... normal sits near 60. Is the module in good exterior condition without corrosion? Connectors are clean?
Do you still have the original pump?
Skenda02
Post by Skenda02 »
Replaced Fuel Pump with brand new out of the box Spectrum pump and Pump Modular is Bosch, brand new from Volvo yesterday.
Skenda02
Post by Skenda02 »
Is there any way to adjust? I don't see a return line on the rail. Or, with pump and module being newer versions, maybe FPS needs to be replaced too? All connections are clean.
oragex
Post by oragex »
Don't think there is adjustment somewhere, but I remember a similar high pressure issue but my memory fails at what was the actual fix. The FPS is pretty much the last unchecked item on the list. These do fail but no idea if it would rise the pressure..
