Thermostat replacement on heated seats.
This topic is in the MVS Volvo Repair Database » Volvo: House calls with App based Pick up and Delivery service
milesursogood
Year and Model: 850 T-5, 1997
Post by milesursogood »
where did you get or buy the new thermostat?
tailor
Year and Model: 2004 XC90 2.5T AWD
Post by tailor »
Sorry about the delay in getting back to you, been away on the high seas!
The thermostats I got were from the scrap yard, I found that some of the seats were torn and the thermostat was sitting in plain site, so I grabbed a few.
I like Mikes approach of attacking the replacement from below, the only advice is do not tear the foam
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
milesursogood
Tailor - Did you have to unplug the battery when removing the seat? Is it fairly easy to disconnect cables & remove the seat? A few bolts. Is there an area that could be difficult in this process, or require some special tool & equipment?
1997 850 T-5 142k miles - Mobil-1
kellyent
Year and Model: 96 850 GLT
Post by kellyent »
The two wires going to the thermostat under my driver's seat are broken off at the clips, and I don't know which one hooks to which clip.
hanzbe420
Year and Model: 2006 s60 2.5T
Post by hanzbe420 »
You don't have to remove anything. you can change them by reaching up under the seat and just pulling the thermostat out the foam hole, disconnect, and replace. Takes 2 mins.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
kellyent wrote: 17 Sep 2016, 22:42 The two wires going to the thermostat under my driver's seat are broken off at the clips, and I don't know which one hooks to which clip.
Not a problem - It’s just a switch,
it’s not polarity sensitive.
Either one to either one.
