Running issue with the '99 wagon. Cold weather no start. I have gotten an immobilizer code on it before, but I think Steve said at one point it was likely a "ghost" code. It did start with a jump a while back. I think I also swapped in a used immobilizer antenna ring just to take that off the table.
The no start is confined to cold weather. When warm it will start right up. This makes me think it is not an immobilizer issue.
The no start symptoms is, however, suspiciously similar to bad immobilizer -- starts, sputters, then dies pretty much immediately and won't restart.
When it was running earlier this week, I took it to Advance Auto Parts for a battery and starting system check. Report was good. Battery state of charge was low, but battery, alternator and starter all tested good. I then put c. 100 highway miles on it to charge up the battery and had no issues. Next attempted cold start it was a no go. Has Xemodex rebuilt throttle body and beefed up battery cables.
Battery is Walmart, but extra capacity due to larger-than-standard size, less than two years old. Could this simply be a bad cell in the battery? Wouldn't that show up in a battery test as something more than low state of charge? Battery was also load tested with cabin blower on full, high beams, etc. Came back OK. This one's a puzzler.
I'm tempted to just go get a new battery since I'll probably get some pro rated credit.
Thoughts?
'99 V70 Auto Base FWD No Start Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 311 times
- Been thanked: 817 times
Have you tried jumpering the fuel pump relay?
- E Showell
No Erik, but not a bad thought. Thanks.
'95 855 auto (sold)
'95 855 auto (sold)
- Been thanked: 4064 times
1999 relay a bit different and position from 1998? Trying to remember. Pictures of 99 fuel pump relay in the 1wagon thread
- E Showell
Nope. Pretty much identical to '98.
'95 855 auto (sold)
'95 855 auto (sold)
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Exact symptoms of a failing fuel pump relay, my bet.
Knows enough to be dangerous
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
How are your temp sensors doing?
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- E Showell
Changed more than once.
'95 855 auto (sold)
'95 855 auto (sold)
Pretty classic fuel pump relay mode if failure. Try a jump on the next no startThe no start is confined to cold weather. When warm it will start right up. This makes me think it is not an immobilizer issue.
- E Showell
I'm going to dig around in my spares and see if I have a junkyard scavenged unit. I'll report back on result (of course JY unit isn't known to be good. . . .)
'95 855 auto (sold)
'95 855 auto (sold)
- 198 Views
Last post by E Showell
- 1015 Views
- 10 Replies
- 2896 Views
Last post by oragex
- 10 Replies
- 5435 Views
Last post by wizechatmgr
- 26 Replies
- 5593 Views
