'99 V70 Auto Base FWD No Start Topic is solved
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Running issue with the '99 wagon. Cold weather no start. I have gotten an immobilizer code on it before, but I think Steve said at one point it was likely a "ghost" code. It did start with a jump a while back. I think I also swapped in a used immobilizer antenna ring just to take that off the table.
The no start is confined to cold weather. When warm it will start right up. This makes me think it is not an immobilizer issue.
The no start symptoms is, however, suspiciously similar to bad immobilizer -- starts, sputters, then dies pretty much immediately and won't restart.
When it was running earlier this week, I took it to Advance Auto Parts for a battery and starting system check. Report was good. Battery state of charge was low, but battery, alternator and starter all tested good. I then put c. 100 highway miles on it to charge up the battery and had no issues. Next attempted cold start it was a no go. Has Xemodex rebuilt throttle body and beefed up battery cables.
Battery is Walmart, but extra capacity due to larger-than-standard size, less than two years old. Could this simply be a bad cell in the battery? Wouldn't that show up in a battery test as something more than low state of charge? Battery was also load tested with cabin blower on full, high beams, etc. Came back OK. This one's a puzzler.
I'm tempted to just go get a new battery since I'll probably get some pro rated credit.
Thoughts?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Have you tried jumpering the fuel pump relay?
E Showell
Post by E Showell »
No Erik, but not a bad thought. Thanks.
'95 855 auto (sold)
Has thanked: 1609 times
Been thanked: 4064 times
1999 relay a bit different and position from 1998? Trying to remember. Pictures of 99 fuel pump relay in the 1wagon thread
E Showell
Post by E Showell »
Nope. Pretty much identical to '98.
'95 855 auto (sold)
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Exact symptoms of a failing fuel pump relay, my bet.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
How are your temp sensors doing?
- S
[Sold] '97 S70 T5
E Showell
Post by E Showell »
Changed more than once.
'95 855 auto (sold)
Pretty classic fuel pump relay mode if failure. Try a jump on the next no start
E Showell
Post by E Showell »
I'm going to dig around in my spares and see if I have a junkyard scavenged unit. I'll report back on result (of course JY unit isn't known to be good. . . .)
'95 855 auto (sold)
