So I just recently discovered my rear passenger side fog light is not working (I'm pretty sure it was tho). I tried changing the bulb but it still doesn't work. When I press the button to have the Lights activated on the dashboard, only the left one on the rear side works.
Anyone have any ideas on how I could fix this?
Thank you.
Fog Light Not Working Topic is solved
- RickHaleParker
- Been thanked: 978 times
You don't need to fix anything. There is only one rear fog light. Two rear fog lights would get confused for break lights.
Active
Past
Past
- Has thanked: 2856 times
- Been thanked: 1332 times
There’s only one.
- kranz
- Year and Model: '98 V70 NA stick
- Been thanked: 8 times
I think it has been mentioned before that having more than one is illegal.
The rear fog light sees greater use in Europe. In northern europe during the winter nights the highways are frequently socked in with heavy fog. As one overtakes a vehicle in the fog, the single red light is the first sign that there is a vehicle ahead. Without it the vehicle is otherwise invisible as the tail lights don't penetrate the fog.
If you import a vehicle to Europe, if you don't have one you will need to install a rear fog light to pass inspection.
Les is more.
- 2615 Views
Last post by SuperHerman
- 6749 Views
Last post by Rokas13
- 1996 Views
Last post by EngineeringBloke
- 1495 Views
Last post by draser
- 985 Views
Last post by xHeart
