No codes leans more to an immobiliser problem than an ECU problem, but you are in rarely charted waters.
VolvoOH (username) had a fried ECU in a recent (past 2 years?) thread
2001 v70 cranks, but no spark...at all
crosscut237
- Year and Model: 2001 v70
- Has thanked: 6 times
I'm not getting any codes or immobiliser messages, I assume I need vida to tell for sure?
crosscut237
I also have checked to make sure that the door locks, windows, everything works......I downloaded VIDA 14, I don't know what to do with it yet though.....so much I have to learn
crosscut237
I gave up and took it to a local volvo specialist, not a dealer though.....Immobiliser was preventing the start....the computer did get messed up....not the right vin#, etc....so they are reprogramming it....I will post what the solution was when I find out.....So pretty sure I need to get a VIDA device if I'm going to keep owning volvos......what is the best way to do this?
crosscut237
Turns out ecm is shot, can anyone point me to someone who can clonemine?
Users Yagger and doublebug are the guys go to for this , about 1/4 the cost of dealer and done at any place with internet, of course
crosscut237
I haven't had any luck getting a hold of either Yagger or doublebug, what other options are there? I heard someone mention ARD I think? My car is an hour away from me now, I'm hoping the shop will let me leave it there for a week or two till I can get this ECU replaced.
- Year and Model: Lots
- Been thanked: 128 times
Yagger is in California. I've had no problem getting through to him and I'm halfway across the world. Try Skype username Sergey (yagger) just as I typed it.
Dice is from fleabay with Vida thrown in
ARD can do it if you supply your ECM to them for cloning. With the other guys you need the Dice diagnostic tool (you don't need Vida to be installed) and an internet connection
If the immobiliser info on your ECM is lost ARD can't help either. Best to use Yagger as he can add a new key to the whole system. You'll also need a new ID48 transponder to insert back into the key head (usually from eBay)
Just fixed mt 1998 with same problem. Took a while. Changed cam ps and crank ps and coil with cheap online parts. Finally was getting a weak spark but plenty of starter motor power. Put a new battery in and cleaned terminals yesterday and all ok at once. Had to run some fuel out the rail end to get it going though first time.Probably had some kind of air lock till relieved.
If your injectors are working the ECU is likely ok.
There are a world of differences between the 1998 and 2001 models on ignition, immobilizer, keys, engine management
Glad you got- it going though!
- 4215 Views
Last post by BestNana1485129
- 865 Views
Last post by jeringo
- 624 Views
- 875 Views
Last post by Acecaci20
- 3704 Views
Last post by Volvo S80
