Part numbers
36000001, 36000000, 8602558, 8603767
I measured the inside snout on the Nissens to see if I can find a metal reinforcement sleeve for the cheaper aftermarket
It measures30 mm or 1 3/16 inch ID. Be careful not to measure the slightly wider piece to the rear.
Behr $100
Nissens. $125
Valeo $300...this is OEM Volvo and has the sleeves included.
P80 Radiators Valero Nissens Behr
tardcart wrote: 31 Mar 2019, 15:19 thats the size of a I" copper pipe. but maby reducing the flow to one inch is too little. are you trying to keep if from cracking?
We have had mostly side tank failures but a few radiator hose snout Snap offs
- Has thanked: 316 times
- Been thanked: 531 times
Yeah, I don't think the Nissens I put in my R had any sleeves. I also had to transfer over the old u-clips to screw the condenser on. The radiator I was replacing was also a Nissens, but I can't quite tell where it failed. All I can say is that it was on the driver side, and the PO had poured some of that nasty metallic stop-leak in there, so I take it that it was a problem long before I had the car. I must have shaken it loose when I drained the coolant for the heater core and timing job. There's still some flakes coming back into the expansion tank Yuck...
The Nissens in my GLT has been good for the 3.5 years I've had it in there.
- 9 Replies
- 1282 Views
- 13 Replies
- 2509 Views
- 456 Views
Last post by foggydogg
- 1365 Views
Last post by kaneelschep
- 13 Replies
- 4269 Views
Last post by BEJinFbk
