Front Suspension - Spring noise - 2001 V70 2.4T
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Oh God, you didn't buy Scantech to save a couple of bucks, did you?
Bad stuff in general
Harleyvh
Year and Model: 2011 S60 T6 AWD
Post by Harleyvh »
Ordered the ball joints through FCP groton.
Supposed to be Meyle or Hamburg Technic according to the site.
Showed up as scantech....
I know, I know... scantech is not too consistent quality wise.....
been there, done that wearing the T-shirt....
Contacted FCP and got a two year warranty on the part....
will see.
2001 V70 2.4T - RIP
2011 S60 T6 AWD - In progress
2004 V40 - "backup"
JRL
Post by JRL »
Harleyvh wrote: Contacted FCP and got a two year warranty on the part....
will see.
Yeah, but no labor
Harleyvh
Post by Harleyvh »
Labor is not an issue at the moment.
I have a good plug at a local mechanic school.,,,
all I have to do is supply the parts....
it's just a PITA to loose time for a replacement and return the bad part.
2001 V70 2.4T - RIP
2004 V40 - "backup"
DieselDoNicely
Year and Model:
Post by DieselDoNicely »
Harleyvh wrote:DDN
After month, Noise was mostly out.
Happening only in deep depression since the 24th... (merry christmas...)
Scantech lower ball joints defective?
I'm planning a visit at the garage in the next two weeks to replace worn out rear brake shoes.... so I'll have a look.
willl keep you posted.
in the meantime... Season's greetings
Good oh, glad you mentioned about the scantech items as I was about to buy a pair. Back to the main stealer for the ball joints then - $100US each in the UK.
Have a good one
DDN
1997 850 Turbo Diesel Auto Estate (390,000 miles)
2003 V70 D5(turbo diesel) Auto Estate - Powerflex poly wishbone bushed :-)
2005 V70 D5(turbo diesel) Geartronic Estate.
FUBAR
Year and Model:
Post by FUBAR »
Additionally, check the power steering level. There is a dip stick that will indicate whether you have lost any fluid. If you believe you may have lost fluid, have a look at the rack/rods. you may find more loose parts.
2001 V70T5 White Exterior/Taupe,Oak Interior, 18" Pegs, Bilstein HD, USA-Spec, volvo coolbox, tint and Xtant 1700watt sub, Blaupunkt components, Kenwood Amp.
sony2000
Year and Model:
Post by sony2000 »
My V70, with 70k miles, needs a lower ball joint now. When it was on the jack, I pulled on the wheel at the 9 o'clock position. There was a surprising amount of play, and it was easy to see the ball joint move out and in. I have been putting together an order for eEuroparts.com, but to my surprise, they don't carry ball joints! Their site is very user friendly, Canadian aware, and competitive, but in my moment of greater need, they have failed me.
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Sony, try control arm. The ball joint is attached to it and the entire control arm (also called A-arm) is replaced. Oh, and avoid ScanTech.
sony2000
Year and Model:
Post by sony2000 »
I found a Lemforder ball joint out of British Columbia for $70, with free shipping. Is there a modification necessary to have the OEM control arm receive the replacement ball joint. Something like welding nuts to the back side of the control arm?
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
Harleyvh
Post by Harleyvh »
Sony
No modification required.
Just some effort to get the thing aligned properly.
On my side, The beautiful streets of Montreal probably got the better of the ball joints installed last november. I'll have the car up to have a look tomorrow.
Not sure about the quality of the Lemforder.
I saw that IPD has them for sales for about 37$ each.
2001 V70 2.4T - RIP
2004 V40 - "backup"
