Fuel filler door won't unlock Topic is solved
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
The DC motors are all the same for almost every car out there. Some have longer shaft or differing gears. Early in the year I followed the same method below and took some copper wire from the Romex and repaired the motor to the 03 S80 T6 door lock actuator.
After taking apart the Fuel Door actuator for cleaning and lubing it still did not work. There is 12V going to the wire connector. No one steals gas here so the actuator is just out till I get to the motor.
Been thanked: 504 times
Post by cn90 »
I think the small electric motor is made by Johnson, I have seen it on ebay for a few dollars.
MoVolvos
Post by MoVolvos »
cn90 wrote: 12 Nov 2019, 20:13 I think the small electric motor is made by Johnson, I have seen it on ebay for a few dollars.
They are very inexpensive on eBay. Just have to make sure the body and shaft are the same. I think I had trouble finding the correct motor without taking it out. I also didn't want to have the door sitting unlocked with a bungie cord to the other door while figuring out and then waiting for the new motor.
Geno9707
Year and Model: 2004 s40
Been thanked: 3 times
Post by Geno9707 »
Geno9707 wrote: 12 Nov 2019, 19:45 Hello everyone.. I had the same issue on my 2004 v70.. I ended up replacing the fuel door lock latch solenoid here is a link where I Bought one for a great price and the video of the link how to replace it..
Fuel door lock latch Solenoid EBay
https://www.ebay.com/itm/353060135687
Yaworski
Year and Model: 2002 S60
Has thanked: 5 times
Post by Yaworski »
My V70s gas door started not unlocking. I found that if I smacked the door really hard it would unlock the next time I unlocked the doors. I cut the locking tab off the door. I'm not overly worried about someone stealing my gas.
Geno9707
Post by Geno9707 »
Geno9707 wrote: 12 Nov 2019, 19:45 Hello everyone.. I had the same issue on my 2004 v70.. I ended up replacing the fuel door lock latch solenoid here is a link where I Bought one for a great price and the video of the link how to replace it.. 99.99% percent its the solenoid that goes bad and not so much the switch. Hope this helps you guys out.
Has thanked: 1609 times
Been thanked: 4065 times
The good news is gas is too cheap to steal. The hose to siphon it costs more than the gas
