These photos are taken on 2005 XC70 with exact same symptom. The guy cut the worn part of the pipe and replaced it with an oil-resistant rubber hose.
The EVAP hose runs to the filler/breather tube. It might be tap to more then one point on the tank. The instructions say to lower the tank. I would look it over real carefully and make sure there is no way to fish a new hose in before dropping the tank.wczimmerman wrote: 24 Feb 2020, 19:11 It's my understanding that the lines in question for that are at the top of the tank anyway...
Not sure if you meant to post any images but they didn't come through with your response.vtl wrote: 24 Feb 2020, 19:25 Check aluminum vent pipe that goes to fuel filler neck, it corrodes and develops holes:
Yes, I put two links to CDN images:wczimmerman wrote: 25 Feb 2020, 09:02 Not sure if you meant to post any images but they didn't come through with your response.
