1998 s70 GLT p0455 assistance
ShadyMilkMan
- Year and Model: 1998 S70
- Has thanked: 3 times
Awesome fellas. Thank you very much! I will be replacing the purge valve even though it doesn't appear to need it (blow test confirmed preliminary tests to be working properly).
ShadyMilkMan
Nice. I love it when a plan comes together.
This is the culprit, yes? The purge valve?
Also, is the other pic of the servo you are talking about, Eddystone? I can't figure out how to get these attachments to fit where they are supposed to. So, pics aren't in order, but I know that one of these is the purge solenoid and the other is not.
- Been thanked: 4071 times
Top one is the turbo control valve. Three connections.
Check the statement above by part number. May well be the SAS valve - see below.
Bottom one is one version of the purge valve with two connections. There is another version which is squarer and looks a lot like the turbo valve but has only two connections.
Pull part numbers off both and post, please. That turbo valve might be aftermarket
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
Abscate, I believe that top valve is the SAS valve for the air pump, not the turbo control valve. It has that metal housing that looks like it slides into the fan cover shroud. Shadymilkman, where did you pull that top valve? If it was just above the radiator that is the SAS valve for the air pump, which you should have since it's a 98 model. I have a few working purge valves. Would be willing to mail you one.abscate wrote: 13 Mar 2020, 03:48 Top one is the turbo control valve. Three connections.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
Thanks Richard.
The turbo solenoid usually lives clipped to the air cleaner, and the SAS solenoid the radiator, as Richard noted.
If its the SAS one hose will go back to a silver alien spaceship living above the exhaust manifold, towards the rear of the engine, right side of engine (in between engine and driver)
Richard99
This is the purge valve you should be looking for. It is located under the air box intake tube.
https://www.fcpeuro.com/products/volvo- ... -9470775oe
Eric
2000 Volvo V70XC
2000 Volvo V70XC
ShadyMilkMan
Alright boys, this is what I found.
This is located on the fan shroud, clipped to it via the metal bracket underneath, hidden inside. This is where I found it: This little guy was below it a little but still in the same general vicinity. Abscate, I think the part numbers are visible via the photos (they are on my end.) If you have any trouble reading them let me know and I will post them in plain text.
Do all of these lil guys need to be replaced, Richard? I'd love it if you could mail me a purge valve. I would be happy to pay for it, and your shipping costs. Thank you very much for the offer!
ShadyMilkMan
Richard, I found it. This is the purge valve that seems to be such a thorn in everyone's paw, huh?Richard99 wrote: 13 Mar 2020, 13:17 This is the purge valve you should be looking for. It is located under the air box intake tube.
Richard99
Yes! That is it. Glad you found it. The tubing going to it looks fairly cracked. You may want to replace that tubing. I hypothesize that part of the reason for the failures is small black particulates getting inside the valve from old tubing.ShadyMilkMan wrote: 13 Mar 2020, 14:30Richard, I found it. This is the purge valve that seems to be such a thorn in everyone's paw, huh?Richard99 wrote: 13 Mar 2020, 13:17 This is the purge valve you should be looking for. It is located under the air box intake tube.
Eric
2000 Volvo V70XC
2000 Volvo V70XC
ShadyMilkMan
Oh, one step ahead of you buddy. I bought a metric shitload of tubing, all types and sizes, to completely overhaul the engine bay. If it looks like a hose and qu(cra)cks like a hose, it's being visited by the taskmaster for sleeping on the job. Is that the valve you have spares of?Richard99 wrote: 13 Mar 2020, 14:32Yes! That is it. Glad you found it. The tubing going to it looks fairly cracked. You may want to replace that tubing. I hypothesize that part of the reason for the failures is small black particulates getting inside the valve from old tubing.ShadyMilkMan wrote: 13 Mar 2020, 14:30Richard, I found it. This is the purge valve that seems to be such a thorn in everyone's paw, huh?Richard99 wrote: 13 Mar 2020, 13:17 This is the purge valve you should be looking for. It is located under the air box intake tube.
- 2559 Views
- 2323 Views
Last post by 800artfreed
- 2602 Views
- 1109 Views
Last post by rgk
- 490 Views
Last post by dosbricks
