Another annoying item on my 19yr old xc70 was the turn signal not self cancelling on the right indicator. I removed the old indicator stalk and tested it in a spare steering module. The cancelling point had moved from 12 o'clock position to about 2 o'clock (see pic) , not sure if its wear as the little tab/tounge didnt look damaged or worn. Installed the spare stalk and fixed the problem now both left and right cancel around 12 o'clock.
No programming was needed all the fuctions of the stalk work. Its plug and play, hope this helps anyone with the same issue.
turn signal not self cancelling fix
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
2001 XC70 factory M58
2002 XC70 auto (parts car)
- Has thanked: 1611 times
- Been thanked: 4075 times
Thanks for fixing them, and even more importantly , wearing them out
Good sarcastic PSA for indicating
crlande
- Year and Model: 240DL;850;S70
- Been thanked: 36 times
Funny. Should have also mentioned to use it well in advance of your intention and nor does it give you the right to merge into traffic just because you had it on!
- 439 Views
Last post by blueechosf
- 1861 Views
Last post by bmayes
- 10 Replies
- 5553 Views
Last post by AnyMajorDude
- 1239 Views
Last post by regent
- 676 Views
Last post by jrbuzz8
