Corona bench tear down, autopsy of,a 1999 9171703 AC compressor
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
Do you have much history on this one? Is that scuffed up swash plate just normal wear and tear after 100,00 miles?
Has thanked: 1609 times
Been thanked: 4064 times
200,000 on that one. It also had about 3-4 years of no AC due to leak so it probably got some contamination too.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
abscate wrote: 28 Apr 2020, 20:00 That front seal is the hard to find/ expensive part.
1/4 the cost of a new compressor
DKS15CH is the Zexel model number. Use DKS15CH to search for parts. You can find Santech parts for a lot less.
DKS15CH uses the same front seal as DKS13G & DKS15BH.
Active
Past
From Johnica.com in Taiwan
I wonder what these cost in low quantity? I could refurbish this 1999 2000 AC for under $50 it’s worth more than a junkyard one.
RickHaleParker
Front seal is Santech MT2043 you can get one at Autozone for $12.99.
Active
Past
850oldschool
I’d buy a few swash plates, if there’s a minimum order from Taiwan.
850oldschool wrote: 30 Apr 2020, 10:35 I’d buy a few swash plates, if there’s a minimum order from Taiwan.
I’ve sent an email to Taiwan to see their distribution model
I have another AC compressor which is growly that I can recondition
I think sharing shipping costs will be the key. It’s about $100 to bring an small package from Taiwan to US
