All the dash lights come on when at KP2. When I turn the key further, to the cranking position, nothing happens (no noise at all)!
Will check the battery voltage once I find my multi-meter and will report back,
1998 V70 AT camshaft position, no crank
5rivers
- Year and Model: V70 1998 T5
- Been thanked: 15 times
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
- Has thanked: 1613 times
- Been thanked: 4078 times
It sounds like a electrical failure of some kind. Starter problems won't affect running, so ignition switch or main battery cables/connections are the suspects.
5rivers
Battery voltage was at 13.4.
I did change the "J" fuse as both sides of one tong (the one labelled "30") had a bit of a black/burnt color to it near the fuse housing.
Again, no noise at all when I turn the key to crank the motor, but the dash lights do come on. This is on the automatic '98 V70.
I am clueless on what to do next!
5rivers
5rivers
There were a few sparks when I connected the negative cable to the battery. Normal?
5rivers
Get a piece of wire stripped on both ends, then put your key in KP2, and try the jump start connection under the kidney fuse box.
This bypasses the key feed, but still needs the starter relay and PnP to be functional, and should start cranking.
Sparking at negative normal, especially if you left your door open.
Stand by for picture.
5rivers
Hi abscate,
I tried the jump starting with the wire as shown in the above photos, but again nothing happened, even with a helper turning the key to the KP3 position.
I took out the ignition sensor from the '98 silver Volvo (std trans) and inserted the bottom half of sensor then screwed everything back in. At least the bells chimed when I left the key in the ignition to perform the jump starting. There was no noise with the initial sensor. The battery was down to 12.5 volts.
Any suggestions on what to try next? Other than find a new sensor!
5rivers
You need to do the same jump down at the starter
Look for the thin blue wire on the starter , pull it off and apply 12 volts to that terminal. See if the starter has any life left in it
Changed title for new issue
5rivers
I'm in the process of disconnecting the wires attached to the starter. Thought I would use a small wire brush to clean up the connections. After I finish this, I will reconnect everything (had to remove the idle air unit to give a bit more room to reach the starter) and try the jump start as you suggest above. I'll keep you posted.
Thanks for hanging in there with me, abscate!! Much appreciated
5rivers
If you make up that same wire I had above I think you could clip that to the small “ blue wire “ terminal on the starter solenoid , then touch the other end to the battery positive.
That sbypassing everything , and if that doesn’t crank , the starter is dead
Those same clips are also useful for holding burning rosemary, sage, or other ceremonial plants.
- 13 Replies
- 3689 Views
- 6861 Views
Last post by prwood
- 1036 Views
- 1671 Views
Last post by cn90
- 639 Views
Last post by jackissocool
