99 V70R - lost reverse
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
Also, adding to the topping. I got suggestion to swap all electronics (pnp switch, sensors, etc) from my 99 to that 2000 trans and it should work. 2000 car was turbo 2.4 but I do not have the vin from it.
Both 1999 and 2000 4 speed trans with Turbo-charged engine models have gear ratio 2.56:1 as far as google search.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
http://volvospeed.com/vs_forum/topic/18 ... omponents/ a lot to digest, but empirical. lots of part number changes spelled out. along with what matches.
Best bet, find a 99 XC or 99 FWD turbo. If you pick FWD, you can sell your angle gear and prop shaft. Or you could re-convert later.
Third pedal option? V50 AWD donor!!!
Current Volvos:
FLXC90
Post by FLXC90 »
https://row52.com/Vehicle/Index/YV1LT56D7X2585552 Here's a 99 AWD in a yard. Looks like they rear-ended someone. Enough damage for insurance to total it, but light enough that I doubt the trans would be bad. You may try to get someone to pull it for you and ship . It has its risks, but possibly its rewards as well.
Current Volvos:
kklepack
Post by kklepack »
FLXC90 wrote: 28 Sep 2020, 18:37 https://row52.com/Vehicle/Index/YV1LT56D7X2585552 Here's a 99 AWD in a yard. Looks like they rear-ended someone. Enough damage for insurance to total it, but light enough that I doubt the trans would be bad. You may try to get someone to pull it for you and ship . It has its risks, but possibly its rewards as well.
Thank you for the link looks like it is in Canada so shipping will most likely expensive. I will keep looking for one closer to Chicago.
On top of it I called dealer's, Erie Vo-Vo, Vandsautodismantlers was not able to get an answer on what is the difference between
99 R vs 99 AWD transmission. Search is still on.
Has thanked: 1611 times
Been thanked: 4075 times
If you look the specs up in the owners manual (online) if there are gear differences those would be listed.
The volvo web store also list options , too
kklepack
Post by kklepack »
abscate wrote: 29 Sep 2020, 09:09 If you look the specs up in the owners manual (online) if there are gear differences those would be listed.
Online Owners Manual for 99V70R and 2000 S70AWD have the same Final drive Turbo-charged models: 2.56:1
Reduction ratios
1st gear 3.61:1
2nd gear 2.06:1
3rd gear 1.37:1
4th gear 0.98:1
Reverse 3.95:1
So, I think these trans are very very similar. Can some one please prove me wrong?
Here’s what I have for you
Same part number for both the T2,and T3 engine variation.
FLXC90
Post by FLXC90 »
The basic transaxles are the same for the AWD(GLT), XC, and AWD (R), it's the suspensions, and in the case of the R, the motor that differ.
Current Volvos:
There is a 1998 XC for sale in Aurora nearby in Classifieds
kklepack
Post by kklepack »
FLXC90 wrote: 29 Sep 2020, 20:54 The basic transaxles are the same for the AWD(GLT), XC, and AWD (R), it's the suspensions, and in the case of the R, the motor that differ.
You are giving me a hope. :-)
