99 V70R - lost reverse
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
So today while backing it to the garage I LOST reverse. Car drives fine forward no issues. When I select R car does not move and I hear transmission wine, I did drain and fill ( 300 miles ago). Anything I can check or look for another trans?
Has thanked: 2215 times
Been thanked: 1853 times
Assuming being a 99 it has the 4 speed auto trans? Normally if the reverse stops working it is the start of the transmission failing.
Did you confirm the oil level when hot is correct?
Has thanked: 1613 times
Been thanked: 4077 times
I’ve got a decent 1998 4 speed already out over here in NY. I could get it as Far west as Buffalo in short order
kklepack
Post by kklepack »
scot850 wrote: 20 Sep 2020, 23:08 Assuming being a 99 it has the 4 speed auto trans? Normally if the reverse stops working it is the start of the transmission failing.
Yes it is 4 speed. I did another drain and fill , took for 20min drive. Checked fluid level while car was dunning and level is between low and hi but closer to low so I will add a little.
I wish yo a lot of luck!
kklepack
Post by kklepack »
scot850 wrote: 21 Sep 2020, 08:51 I wish yo a lot of luck!
Thank you, I will need it.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
When my 1998 GLT S70 lost an exhaust valve at 175K, I drove it (w the #3 injector d/c'd).
At 185K, I lost reverse. It was the final straw. Traded the car for $350. Bought a 2004 V70 w 100K...
kklepack
Post by kklepack »
I found trans from V70 AWD with 130K for $400. Is the price fair?
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
I'd rather jump on Abscate's offer because it is known to be good.
But yes, 400 is alrightish, I guess.
1996 855 R,
2010 V70 D5,
Give Erie VoVo a call and see what they ask.
It’s all in the logistics of shipping of course.
Mine is available vs the FDPP which is to say anything you care to pay gets donated back to board or if times are tight it’s a $0 item to you
Thanks for being a MVS Contributor here.
