2000 V70 AWD automatic 56 engine.
Very very slow coolant leak. Any of you seasoned vets (Im still Volvo novice) pertaining to the likely culpret?
My first idea is to (rent a car to get to san diego, too risky) but for this car, get it up to full heat, lift it up, inspect under engine for signs of slow leak residue.
Thanks you all you previously helpful wise owls. I'm too old to figure a Volvo out though I have higher ability slowly slowly over time.
thx in advance.
2000 V70 AWD 56 engine slow coolant leak
- Has thanked: 1611 times
- Been thanked: 4071 times
Usual culprits
Rear of engine (technically the right side of engine, but whatever...) two small coolant hoses that service the turbo on your AWD car. They are cheap but a bit sus scrofa to replace.
The overflow reservoirs usually crack after about 15 years
Dont go cheap or aftermarket on cooling parts, many a fool has been separated froma good Vovlo engine by the Siren Song of cheap aftermarket cooling parts.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
+1 on all of the above.
I actually had a minute hairline crack in the radiator itself, where the plastic sides are crimped to the frame of the core.
Drove me nuts because it would just drip into the splash guard and probably run out went I went down the hill from my house. Never had a drip in the garage but the coolant level went down ever so slow.
Good Luck
Good Luck
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
motormikeyman
- Year and Model: 2004 XC70 AWD
- Been thanked: 8 times
I had similar problem as 850LPT. A very slow leak where the plastic radiator side tank was crimped to the aluminum radiator core on the lower passenger side. I got a new radiator to install but it actually blocked itself up after a while and stopped leaking, I call that a win!
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
Rocket99
- Year and Model: 2000 V70 XC
- Has thanked: 56 times
yes thx for these point. I did engine trashing once already (total luck to fine exact 56 engine with 72K miles for $950) when this car was new to me and I was stressed way overboard and not focussed will, didn't know Volvos AT ALL. So, now Im being cautious not to do that again.abscate wrote: 19 May 2021, 11:48 Usual culprits
have new V. radiator, coolant reservoir.
One new volvo radiator arrived with the flimsy small nipple snapped off so they shipped a new one.
Rocket99
why did it load the pic four times?
that is the repair for future use as spare NEW radiator. I plan to embed the brass nipple in JB weld regular which adheres to plastic real good.
- Has thanked: 311 times
- Been thanked: 817 times
Gesture noted but if you don't get it correct, then you haven't appeased the pedants!abscate wrote: 19 May 2021, 11:48 ... Rear of engine (technically the right side of engine, but whatever...) ...
I have nothing useful to add to the thread, the advice is looking good to me.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Is it leaving a puddle under the car, or is the coolant slowing leaving the reservoir with no external signs of leakage?
Rocket99
no no
I was traumatized while a volvochild very young and never got over it had to replace engine
. Nothing on the ground, takes maybe 2 or more months to drop 1 inch.
just carry some along with....
