Vida CEM swapping
NuovoRecord
Year and Model: 2004 V70
Post by NuovoRecord »
This is such a cool and useful project. Is there any chance that it will work on 2004s soon?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
NuovoRecord wrote: 01 Aug 2021, 21:20 This is such a cool and useful project. Is there any chance that it will work on 2004s soon?
If somebody can come up with a side attack that works on a P2 CEM-B ( MY -2004 ). So far nobody has found anything exploitable.
The side attack we have how works on P1, P2 CEM-L & CEM-H ( MY 2005+ ).
Active
Past
ricked
Year and Model: xc90
Has thanked: 6 times
Post by ricked »
vtl wrote: 01 Aug 2021, 08:58 "DBG NORM: -1" is printed by the FlexCAN_T4 library: https://github.com/tonton81/FlexCAN_T4/ ... .tpp#L1092 I don't know what it means.
Could you paste the log for the first byte, and also the pin you read with xprog/ioterminal?
pincode is 223549122494 and is correct as i did login with it
second log in my post is the one this pin belongs to so the one the cracker can not read, but the part number is in the script
Part Number: 30765015
V50 year 2006 cem with 2x 0L01Y MCU’s
first outcome was:
48 33 -- -- -- --
second:
58 28 68 -- -- --
RickHaleParker
RHP PT V2.1 Its cracking.
Did way with the Buck Converter. Tennesy 4.0 100mA, Bosch CF160 80mA. 100 mA + 2 x 80mA = 260mA. Not going to over load any USB port. No terminating resistors. Just the Tennsy 4.0 and two Bosch CF160 CAN transceivers.
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
ricked wrote: 02 Aug 2021, 00:20 pincode is 223549122494 and is correct as i did login with it
Use the latest code, the one with #define LAT_ONLY.
ricked
Post by ricked »
vtl wrote: 02 Aug 2021, 06:06
just run it? no need to edit something in script?
edit
pin found!! with new script and its faster in my case also
if the latency approach does not work must we comment it out or leave it in as old script works with my spare?
log for your info:
Code: Select all
CPU Maximum Frequency:   600000000
CPU Frequency:           600000000
Execution Rate:          600 cycles/us
PIN bytes to measure:    3
Number of samples:       100
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
CAN_LS <--- ID=04301090 data=00 00 00 00 00 00 00 00
CAN_LS <--- ID=09c050b8 data=48 00 02 00 00 00 00 4c
CAN_LS <--- ID=19f010f8 data=80 00 00 00 00 00 05 60
CAN_LS <--- ID=00600005 data=8f 40 f9 f0 00 30 76 50
CAN_LS <--- ID=065373ba data=c4 00 20 c0 1b 00 00 9c
CAN_LS <--- ID=0a90f698 data=08 d3 00 00 00 00 00 00
CAN_LS <--- ID=13f041ba data=00 40 1f ff 80 00 00 00
CAN_LS <--- ID=1ad10068 data=28 44 00 00 fc 43 33 24
CAN_LS <--- ID=02120498 data=10 00 00 00 00 00 00 00
CAN_LS <--- ID=03c3f7fc data=00 00 00 00 00 20 18 00
CAN_LS <--- ID=00600005 data=09 15 20 20 20 31 26 46
Searching P/N 30765015 in 49 known CEMs
CAN HS baud rate: 500000
PIN shuffle order: 0 1 2 3 4 5
CAN high-speed init done.
Putting all ECUs into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=50 88 00 00 00 00 00 00
CAN_HS <--- ID=00000003 data=50 8e 00 00 30 76 50 15
Initialization done.
Calculating bytes 0-2
1000 pins in 702 ms, 1424 pins/s, average response: 151 us, histogram 75 to 226 us
                   us:   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162
[ 00 -- -- -- -- -- ]:     0  1152     0    51     0     0     0     0     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1409176; std 380.60
[ 01 -- -- -- -- -- ]:     1  3948     0  1172     0    59     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429267; std 384.68
[ 02 -- -- -- -- -- ]:     0  3921     0  1100     0    59     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428705; std 383.71
[ 03 -- -- -- -- -- ]:     0  3978     0  1165     0    58     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429236; std 382.72
[ 04 -- -- -- -- -- ]:     0  3572     0  1014     0    42     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1426698; std 371.28
[ 05 -- -- -- -- -- ]:     0  3978     0  1180     0    46     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429280; std 382.96
[ 06 -- -- -- -- -- ]:     0  3840     0  1135     0    56     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1428712; std 380.59
[ 07 -- -- -- -- -- ]:     0  3948     0  1188     0    48     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429296; std 383.47
[ 08 -- -- -- -- -- ]:     0  2964     0   773     0    28     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1422534; std 360.88
[ 09 -- -- -- -- -- ]:     0  3935     0  1180     0    58     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429318; std 383.00
[ 10 -- -- -- -- -- ]:     0  1722     0   268     0    10     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1413580; std 369.88
[ 11 -- -- -- -- -- ]:     0  3977     0  1187     0    54     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429270; std 381.46
[ 12 -- -- -- -- -- ]:     0  3893     0  1150     0    61     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428696; std 376.47
[ 13 -- -- -- -- -- ]:     0  3941     0  1169     0    64     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429314; std 382.90
[ 14 -- -- -- -- -- ]:     0  3516     0  1029     0    54     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1426598; std 367.42
[ 15 -- -- -- -- -- ]:     0  3959     0  1209     0    44     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429308; std 383.80
[ 16 -- -- -- -- -- ]:     0  3766     0  1164     0    71     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428686; std 376.70
[ 17 -- -- -- -- -- ]:     0  3903     0  1202     0    62     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429278; std 380.51
[ 18 -- -- -- -- -- ]:     0  2882     0   807     0    21     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1422518; std 358.89
[ 19 -- -- -- -- -- ]:     0  3887     0  1177     0    66     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429264; std 382.68
[ 20 -- -- -- -- -- ]:     0  3967     0  1178     0    61     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429314; std 381.91
[ 21 -- -- -- -- -- ]:     0  3391     0  3887     0  1177     0    55     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449120; std 382.13
[ 22 -- -- -- -- -- ]:     0  1445     0  3521     0  3642     0   973     0    12     0     1     0     0     0     0     0     0     0     1 : latency    1466648; std 375.79
[ 23 -- -- -- -- -- ]:     0  3296     1  4006     0  1141     0    54     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449201; std 386.46
[ 24 -- -- -- -- -- ]:     0  3461     0  3604     0  1013     0    51     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1446802; std 373.15
[ 25 -- -- -- -- -- ]:     0  3330     0  3917     0  1203     0    37     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449150; std 381.70
[ 26 -- -- -- -- -- ]:     0  3300     0  3953     0  1124     0    56     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448856; std 379.37
[ 27 -- -- -- -- -- ]:     0  3341     0  3941     0  1169     0    48     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449146; std 382.98
[ 28 -- -- -- -- -- ]:     0  3708     0  2968     0   758     0    29     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1442621; std 363.91
[ 29 -- -- -- -- -- ]:     0  3328     0  3937     0  1184     0    38     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449156; std 382.76
[ 30 -- -- -- -- -- ]:     0  3855     0  1770     0   279     0    11     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1433642; std 366.25
[ 31 -- -- -- -- -- ]:     0  3354     0  3906     0  1200     0    42     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449210; std 382.11
[ 32 -- -- -- -- -- ]:     0  3327     0  3863     0  1195     0    40     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448832; std 376.25
[ 33 -- -- -- -- -- ]:     0  3364     0  3894     0  1193     0    41     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449164; std 382.32
[ 34 -- -- -- -- -- ]:     0  3506     0  3568     0  1024     0    42     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1446802; std 371.77
[ 35 -- -- -- -- -- ]:     0  3352     0  3902     0  1179     0    57     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449172; std 381.52
[ 36 -- -- -- -- -- ]:     0  3305     0  3864     0  1184     0    47     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448790; std 377.82
[ 37 -- -- -- -- -- ]:     0  3362     0  3896     0  1176     0    58     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449184; std 381.80
[ 38 -- -- -- -- -- ]:     0  3673     1  2966     0   789     0    25     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1442607; std 360.53
[ 39 -- -- -- -- -- ]:     0  3397     0  3901     0  1192     0    47     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449242; std 383.25
[ 40 -- -- -- -- -- ]:     0  3852     0  1146     0    49     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428726; std 382.72
[ 41 -- -- -- -- -- ]:     0  3884     0  1215     0    50     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429340; std 379.78
[ 42 -- -- -- -- -- ]:     0  3394     0  3811     0  1174     0    48     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448766; std 378.93
[ 43 -- -- -- -- -- ]:     0  3323     2  3959     0  1175     0    54     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449294; std 385.34
[ 44 -- -- -- -- -- ]:     0  3426     0  3608     0  1014     0    42     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1446740; std 370.50
[ 45 -- -- -- -- -- ]:     0  3396     0  3867     0  1215     0    47     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449272; std 381.87
[ 46 -- -- -- -- -- ]:     0  3364     0  3845     0  1162     0    47     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448758; std 379.36
[ 47 -- -- -- -- -- ]:     0  3342     0  3917     0  1211     0    41     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449302; std 382.31
[ 48 -- -- -- -- -- ]:     0  3585     0  3005     0   754     0    39     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1442482; std 356.48
[ 49 -- -- -- -- -- ]:     0  3371     0  3894     0  1199     0    58     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449268; std 381.62
[ 50 -- -- -- -- -- ]:     0  3996     0  1673     0   265     0    15     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1433588; std 370.59
[ 51 -- -- -- -- -- ]:     0  3318     0  3958     0  1185     0    52     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449320; std 382.93
[ 52 -- -- -- -- -- ]:     0  3335     0  3837     0  1163     0    53     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448704; std 375.48
[ 53 -- -- -- -- -- ]:     1  3370     0  3884     0  1228     0    47     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449383; std 383.91
[ 54 -- -- -- -- -- ]:     0  3400     0  3558     0  1037     0    45     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1446670; std 367.57
[ 55 -- -- -- -- -- ]:     0  3305     0  3949     0  1201     0    49     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449332; std 382.11
[ 56 -- -- -- -- -- ]:     0  3371     0  3869     0  1149     0    50     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448766; std 380.30
[ 57 -- -- -- -- -- ]:     0  3352     0  3926     0  1202     0    48     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449340; std 382.79
[ 58 -- -- -- -- -- ]:     0  3635     0  2918     0   802     0    31     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1442482; std 356.26
[ 59 -- -- -- -- -- ]:     0  3334     1  3934     0  1198     0    47     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449283; std 384.63
[ 60 -- -- -- -- -- ]:     1  3955     0  1172     0    58     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1429299; std 385.04
[ 61 -- -- -- -- -- ]:     0  3392     1  3919     0  1151     0    54     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449169; std 386.34
[ 62 -- -- -- -- -- ]:     0  3416     0  3819     0  1176     0    58     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448866; std 379.43
[ 63 -- -- -- -- -- ]:     0  3379     0  3890     0  1179     0    59     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449194; std 381.98
[ 64 -- -- -- -- -- ]:     0  3492     1  3568     0  1012     0    55     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1446803; std 375.45
[ 65 -- -- -- -- -- ]:     0  3406     0  3935     0  1141     0    55     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449212; std 387.66
[ 66 -- -- -- -- -- ]:     0  3334     0  3870     0  1191     0    38     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448886; std 379.48
[ 67 -- -- -- -- -- ]:     0  3353     0  3925     0  1166     0    50     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449192; std 383.37
[ 68 -- -- -- -- -- ]:     0  3660     0  2972     0   779     0    27     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1442608; std 358.94
[ 69 -- -- -- -- -- ]:     0  3401     1  3861     0  1199     0    43     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449083; std 381.41
[ 70 -- -- -- -- -- ]:     0  3901     0  1774     0   278     0     8     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1433704; std 364.47
[ 71 -- -- -- -- -- ]:     0  3384     0  3925     0  1190     0    42     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449254; std 383.95
[ 72 -- -- -- -- -- ]:     0  3292     0  3957     0  1127     0    53     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448852; std 381.45
[ 73 -- -- -- -- -- ]:     0  3367     0  3898     0  1173     0    64     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449216; std 381.71
[ 74 -- -- -- -- -- ]:     0  3467     0  3580     0  1014     0    52     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1446832; std 371.01
[ 75 -- -- -- -- -- ]:     0  3367     0  3926     0  1178     0    51     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449370; std 378.87
[ 76 -- -- -- -- -- ]:     0  3273     0  3894     0  1177     0    45     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448818; std 380.42
[ 77 -- -- -- -- -- ]:     0  3387     0  3904     0  1170     0    61     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449256; std 383.17
[ 78 -- -- -- -- -- ]:     1  3631     0  2974     0   780     0    33     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1442581; std 359.68
[ 79 -- -- -- -- -- ]:     0  3286     0  3966     0  1176     0    45     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449204; std 382.46
[ 80 -- -- -- -- -- ]:     0  3570     0  1025     0    43     0     0     0     1     0     0     0     0     0     0     0     0     0     0 : latency    1426730; std 370.15
[ 81 -- -- -- -- -- ]:     0  3940     0  1193     0    51     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429308; std 380.05
[ 82 -- -- -- -- -- ]:     0  3838     0  1178     0    48     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428744; std 377.59
[ 83 -- -- -- -- -- ]:     1  3950     0  1196     0    53     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429315; std 381.32
[ 84 -- -- -- -- -- ]:     0  3476     0  3557     0  1018     0    50     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1446698; std 369.91
[ 85 -- -- -- -- -- ]:     0  3338     0  3960     0  1176     0    53     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1449344; std 383.99
[ 86 -- -- -- -- -- ]:     0  3376     0  3820     0  1175     0    52     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448778; std 378.47
[ 87 -- -- -- -- -- ]:     0  3300     0  3945     0  1193     0    50     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449290; std 382.01
[ 88 -- -- -- -- -- ]:     0  3608     0  2967     0   779     0    29     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1442480; std 359.24
[ 89 -- -- -- -- -- ]:     0  3251     0  3949     0  1219     0    45     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449282; std 380.25
[ 90 -- -- -- -- -- ]:     0  3960     0  1743     0   262     0     3     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1433624; std 368.00
[ 91 -- -- -- -- -- ]:     0  3358     0  3899     0  1206     0    50     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449254; std 379.39
[ 92 -- -- -- -- -- ]:     0  3328     0  3903     0  1154     0    41     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448786; std 378.37
[ 93 -- -- -- -- -- ]:     0  3352     0  3873     0  1225     0    49     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449232; std 380.01
[ 94 -- -- -- -- -- ]:     0  3530     1  3518     0  1050     0    34     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1446759; std 373.03
[ 95 -- -- -- -- -- ]:     0  3324     0  3912     0  1199     0    59     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449260; std 380.73
[ 96 -- -- -- -- -- ]:     0  3360     0  3837     0  1154     0    55     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448750; std 381.21
[ 97 -- -- -- -- -- ]:     0  3323     0  3949     0  1185     0    53     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449300; std 382.71
[ 98 -- -- -- -- -- ]:     0  3605     0  2970     0   767     0    36     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1442464; std 356.67
[ 99 -- -- -- -- -- ]:     0  3369     0  3905     0  1214     0    40     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449268; std 380.27
best candidates ordered by latency:
0: 22 lat = 1466648
1: 53 lat = 1449383
2: 75 lat = 1449370
3: 85 lat = 1449344
4: 57 lat = 1449340
95: 14 lat = 1426598
96: 08 lat = 1422534
97: 18 lat = 1422518
98: 10 lat = 1413580
99: 00 lat = 1409176
best candidates ordered by std:
0: 65 std = 387.66
1: 23 std = 386.46
2: 61 std = 386.34
3: 43 std = 385.34
4: 60 std = 385.04
95: 68 std = 358.94
96: 18 std = 358.89
97: 98 std = 356.67
98: 48 std = 356.48
99: 58 std = 356.26
lat_k 0-1 1.19%, lat_k 98-99 0.31%, lat_k 0-99 4.08%
std_k 0-1 0.31%, std_k 98-99 0.06%, std_k 0-99 8.81%
pin[0] choose candidate: 22 (latency only)
[ 22 00 -- -- -- -- ]:     0  1769     0  3757     0  3397     0   568     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1463218; std 377.75
[ 22 01 -- -- -- -- ]:     0   586     0  2183     0  4074     0  3051     0     0     0     0     0     0     0     0     0     0     0     1 : latency    1478620; std 392.59
[ 22 02 -- -- -- -- ]:     0   601     1  2194     0  4102     0  2977     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1478263; std 393.45
[ 22 03 -- -- -- -- ]:     0   575     0  2147     0  4183     0  3001     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1478720; std 396.19
[ 22 04 -- -- -- -- ]:     0   728     0  2479     0  3991     0  2645     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1476316; std 378.37
[ 22 05 -- -- -- -- ]:     0   569     0  2144     0  4111     0  3048     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1478598; std 393.42
[ 22 06 -- -- -- -- ]:     0   688     0  2175     0  4013     0  3028     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1478242; std 385.88
[ 22 07 -- -- -- -- ]:     0   576     1  2157     0  4138     0  3028     0     0     0     0     0     0     0     0     0     0     0     1 : latency    1478699; std 394.78
[ 22 08 -- -- -- -- ]:     0  1146     0  2817     0  3768     0  2008     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1472080; std 361.99
[ 22 09 -- -- -- -- ]:     0   572     0  2134     0  4107     0  3092     0     0     0     0     0     0     0     0     0     0     0     1 : latency    1478926; std 392.95
[ 22 10 -- -- -- -- ]:     0   469     0  1744     0  3679     0  3467     0   562     0     0     0     1     0     0     0     0     0     0 : latency    1483202; std 376.34
[ 22 11 -- -- -- -- ]:     0    78     0   590     0  2142     0  4068     0  3113     0     0     0     0     0     0     0     0     0     1 : latency    1498928; std 391.82
[ 22 12 -- -- -- -- ]:     0    80     0   627     0  2181     0  4103     0  2998     0     0     0     0     0     0     0     0     0     0 : latency    1498446; std 390.10
[ 22 13 -- -- -- -- ]:     0    91     0   605     0  2119     0  4092     0  3088     0     0     0     0     0     0     0     0     0     1 : latency    1498818; std 391.50
[ 22 14 -- -- -- -- ]:     0   135     0   844     0  2351     0  3949     0  2705     0     0     0     0     0     0     0     0     0     0 : latency    1496278; std 376.63
[ 22 15 -- -- -- -- ]:     0    78     0   594     0  2171     0  4034     0  3116     0     0     0     0     0     0     0     0     0     1 : latency    1498876; std 390.74
[ 22 16 -- -- -- -- ]:     0   111     0   614     0  2160     0  4083     0  3022     0     0     0     0     0     0     0     1     0     0 : latency    1498406; std 389.08
[ 22 17 -- -- -- -- ]:     0    97     0   613     0  2126     0  4004     0  3148     0     0     0     0     0     0     0     0     0     0 : latency    1498800; std 391.10
[ 22 18 -- -- -- -- ]:     0   229     0  1082     0  2871     0  3866     0  1925     0     0     0     0     0     0     0     1     0     0 : latency    1492072; std 367.27
[ 22 19 -- -- -- -- ]:     0   109     0   592     0  2134     0  4097     0  3054     0     0     0     0     0     0     0     1     0     0 : latency    1498590; std 390.52
[ 22 20 -- -- -- -- ]:     0   576     0  2094     0  4230     0  3000     0     0     0     0     0     0     0     0     0     0     0     1 : latency    1478774; std 395.48
[ 22 21 -- -- -- -- ]:     0   111     0   585     0  2107     0  4162     0  3022     0     0     0     0     0     0     0     0     0     0 : latency    1498604; std 394.49
[ 22 22 -- -- -- -- ]:     0   103     0   611     0  2221     0  4061     0  2992     0     0     0     0     0     0     0     0     0     0 : latency    1498272; std 388.24
[ 22 23 -- -- -- -- ]:     0    76     0   605     0  2127     0  4134     0  3046     0     0     0     0     0     0     0     1     0     0 : latency    1498746; std 394.62
[ 22 24 -- -- -- -- ]:     0   117     0   750     0  2488     0  3985     0  2644     0     0     0     0     0     0     0     0     0     1 : latency    1496366; std 380.72
[ 22 25 -- -- -- -- ]:     0    81     0   566     0  2257     0  3985     0  3096     0     0     0     0     0     0     0     0     0     1 : latency    1498694; std 389.32
[ 22 26 -- -- -- -- ]:     0    96     0   611     0  2246     0  4028     0  3007     0     0     0     0     0     0     0     0     0     1 : latency    1498292; std 387.67
[ 22 27 -- -- -- -- ]:     0    82     0   583     0  2155     0  4144     0  3027     0     0     0     0     0     0     0     0     0     1 : latency    1498734; std 393.04
[ 22 28 -- -- -- -- ]:     0   246     0  1077     0  2863     0  3782     0  2000     0     0     0     0     0     0     0     1     0     0 : latency    1492114; std 363.68
[ 22 29 -- -- -- -- ]:     0    87     0   531     0  2186     0  4086     0  3096     0     0     0     0     0     0     0     0     0     0 : latency    1498948; std 395.33
[ 22 30 -- -- -- -- ]:     0   464     0  1813     0  3627     0  3433     0   587     0     0     0     0     0     1     0     0     0     0 : latency    1483130; std 375.50
[ 22 31 -- -- -- -- ]:     0    72     0   597     0  2132     0  4113     0  3081     0     0     0     0     0     0     0     0     0     1 : latency    1498924; std 392.95
[ 22 32 -- -- -- -- ]:     0    94     0   657     0  2108     0  4129     0  3000     0     0     0     0     0     0     0     0     0     0 : latency    1498516; std 389.71
[ 22 33 -- -- -- -- ]:     0   107     0   574     0  2121     0  4069     0  3115     0     0     0     0     0     0     0     0     0     0 : latency    1498824; std 393.23
[ 22 34 -- -- -- -- ]:     0   160     0   773     0  2419     0  3932     0  2697     0     0     0     0     0     1     0     0     0     0 : latency    1496234; std 374.78
[ 22 35 -- -- -- -- ]:     0    11     0   116     0   809     0  2396     0  3924     1  2706     0    34     0     0     0     0     0     0 : latency    1516597; std 378.48
[ 22 36 -- -- -- -- ]:     0    95     0   606     0  2237     0  4007     0  3042     0     0     0     0     0     0     0     1     0     0 : latency    1498390; std 389.77
[ 22 37 -- -- -- -- ]:     0    83     0   621     0  2140     0  3998     0  3150     0     0     0     0     0     0     0     0     0     1 : latency    1498860; std 389.25
[ 22 38 -- -- -- -- ]:     0   221     0  1101     0  2848     0  3855     0  1946     0     0     0     0     0     0     0     0     0     1 : latency    1492118; std 366.39
[ 22 39 -- -- -- -- ]:     0    85     0   608     0  2155     0  4091     0  3049     0     0     0     0     0     0     0     0     0     1 : latency    1498636; std 390.73
[ 22 40 -- -- -- -- ]:     0   653     0  2194     0  4061     0  3002     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1478340; std 388.16
[ 22 41 -- -- -- -- ]:     0   610     0  2158     0  4054     0  3071     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1478616; std 389.47
[ 22 42 -- -- -- -- ]:     0   109     0   603     0  2207     0  4055     0  3007     0     0     0     0     0     0     0     1     0     0 : latency    1498266; std 388.00
[ 22 43 -- -- -- -- ]:     0    83     0   603     0  2130     0  4123     0  3049     0     0     0     0     0     0     0     0     0     0 : latency    1498720; std 392.00
[ 22 44 -- -- -- -- ]:     0   112     0   760     0  2437     0  4084     0  2591     0     0     0     0     0     0     0     1     0     0 : latency    1496350; std 383.19
[ 22 45 -- -- -- -- ]:     0    99     0   562     0  2150     0  4176     0  3002     0     0     0     0     0     0     0     0     0     1 : latency    1498660; std 393.65
[ 22 46 -- -- -- -- ]:     0   102     0   636     0  2173     0  4078     0  3002     0     0     0     0     0     1     0     0     0     0 : latency    1498312; std 388.40
[ 22 47 -- -- -- -- ]:     0    84     0   547     0  2225     0  4100     0  3034     0     0     0     0     0     0     0     0     0     0 : latency    1498732; std 394.68
[ 22 48 -- -- -- -- ]:     0   239     0  1081     0  2845     0  3826     0  1978     0     0     0     0     0     0     0     1     0     0 : latency    1492136; std 367.30
[ 22 49 -- -- -- -- ]:     0    79     0   559     0  2227     0  3978     0  3148     0     0     0     0     0     0     0     0     0     0 : latency    1498948; std 390.39
[ 22 50 -- -- -- -- ]:     0   474     0  1740     0  3642     0  3479     0   572     0     0     0     0     0     0     0     0     0     1 : latency    1483172; std 374.72
[ 22 51 -- -- -- -- ]:     0    83     0   586     0  2148     0  4061     0  3112     0     0     0     0     0     0     0     0     0     0 : latency    1498894; std 391.47
[ 22 52 -- -- -- -- ]:     0   100     0   588     0  2252     1  4006     0  3038     0     0     0     0     0     0     0     0     0     0 : latency    1498385; std 392.01
[ 22 53 -- -- -- -- ]:     0    94     0   588     0  2219     0  3899     0  3187     0     0     0     0     0     0     0     0     0     0 : latency    1498804; std 387.19
[ 22 54 -- -- -- -- ]:     0   139     0   780     0  2421     0  3965     0  2675     0     0     0     0     0     0     0     0     0     1 : latency    1496280; std 376.16
[ 22 55 -- -- -- -- ]:     0    75     0   544     0  2243     0  4015     0  3113     0     0     0     0     0     0     0     0     0     0 : latency    1498922; std 391.50
[ 22 56 -- -- -- -- ]:     0    97     0   580     0  2206     0  4101     0  3000     0     0     0     0     0     0     0     0     0     1 : latency    1498438; std 392.65
[ 22 57 -- -- -- -- ]:     0   103     0   602     0  2082     0  4090     1  3110     0     0     0     0     0     0     0     1     0     0 : latency    1498819; std 393.31
[ 22 58 -- -- -- -- ]:     0   218     0  1092     0  2873     0  3869     0  1923     0     0     0     0     0     0     0     0     0     1 : latency    1492106; std 367.66
[ 22 59 -- -- -- -- ]:     0   101     0   573     0  2120     0  4168     0  3017     0     0     0     0     0     0     0     0     0     1 : latency    1498614; std 392.88
[ 22 60 -- -- -- -- ]:     0   560     0  2222     0  4110     0  3031     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1478790; std 393.11
[ 22 61 -- -- -- -- ]:     0   104     0   584     0  2168     0  4052     0  3077     0     0     0     0     0     0     0     0     0     0 : latency    1498624; std 391.88
[ 22 62 -- -- -- -- ]:     0    94     0   656     0  2164     0  4097     0  2983     0     0     0     0     0     0     0     0     0     1 : latency    1498288; std 388.63
[ 22 63 -- -- -- -- ]:     0    89     0   555     0  2197     0  4099     0  3050     0     0     0     0     0     0     0     0     0     1 : latency    1498758; std 392.37
[ 22 64 -- -- -- -- ]:     0   139     0   755     0  2374     0  4110     0  2601     0     0     0     0     0     0     0     0     0     0 : latency    1496320; std 380.68
[ 22 65 -- -- -- -- ]:     0    94     0   596     0  2145     0  4103     0  3050     0     0     0     0     0     0     0     0     0     1 : latency    1498652; std 391.15
[ 22 66 -- -- -- -- ]:     0   122     0   612     0  2167     1  4105     0  2980     0     0     0     0     0     0     0     1     0     0 : latency    1498219; std 392.96
[ 22 67 -- -- -- -- ]:     0    95     0   564     0  2168     0  4133     0  3031     0     0     0     0     0     0     0     1     0     0 : latency    1498712; std 392.78
[ 22 68 -- -- -- -- ]:     0   246     0  1060     0  2889     0  3765     0  1996     0     0     0     0     0     1     0     0     0     0 : latency    1492026; std 363.40
[ 22 69 -- -- -- -- ]:     0    89     0   564     0  2115     0  4149     0  3072     0     0     0     0     0     0     0     0     0     1 : latency    1498920; std 396.18
[ 22 70 -- -- -- -- ]:     0   483     0  1762     0  3621     0  3488     0   564     0     0     0     0     0     0     0     1     0     0 : latency    1483150; std 374.60
[ 22 71 -- -- -- -- ]:     0    82     0   554     0  2200     0  4022     0  3132     0     0     0     0     0     0     0     0     0     1 : latency    1498962; std 391.46
[ 22 72 -- -- -- -- ]:     0    85     0   631     0  2226     0  4004     0  3042     0     0     0     0     0     0     0     0     0     0 : latency    1498390; std 387.27
[ 22 73 -- -- -- -- ]:     0    91     0   612     0  2137     0  4013     0  3139     0     0     0     0     0     0     0     0     0     1 : latency    1498832; std 389.49
[ 22 74 -- -- -- -- ]:     0   164     0   772     0  2412     0  3929     0  2702     0     0     0     0     0     0     0     1     0     0 : latency    1496220; std 376.71
[ 22 75 -- -- -- -- ]:     0    92     0   562     0  2144     0  4106     0  3088     0     0     0     0     0     0     0     0     0     1 : latency    1498908; std 395.05
[ 22 76 -- -- -- -- ]:     0    87     0   651     0  2142     0  4126     0  2985     0     0     0     0     0     0     0     0     0     1 : latency    1498370; std 392.00
[ 22 77 -- -- -- -- ]:     0    95     0   602     0  2116     0  4058     0  3118     0     0     0     0     0     0     0     0     0     1 : latency    1498824; std 390.60
[ 22 78 -- -- -- -- ]:     0   239     1  1068     0  2909     0  3814     0  1947     0     0     0     0     0     0     0     0     0     1 : latency    1492073; std 368.44
[ 22 79 -- -- -- -- ]:     0    88     0   592     0  2165     0  4105     0  3038     0     0     0     0     0     0     0     0     0     0 : latency    1498640; std 393.46
[ 22 80 -- -- -- -- ]:     0   749     0  2400     0  4118     0  2574     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1476248; std 381.04
[ 22 81 -- -- -- -- ]:     0   592     0  2136     0  4137     0  3043     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1478764; std 392.77
[ 22 82 -- -- -- -- ]:     0   637     0  2192     0  4058     0  2995     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1478218; std 387.38
[ 22 83 -- -- -- -- ]:     0   561     0  2202     0  4108     0  3041     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1478786; std 392.76
[ 22 84 -- -- -- -- ]:     0   120     0   817     0  2387     0  4053     0  2608     0     0     0     0     0     1     0     0     0     0 : latency    1496214; std 380.47
[ 22 85 -- -- -- -- ]:     0   107     0   589     0  2123     0  4089     0  3073     0     0     0     0     0     1     0     0     0     0 : latency    1498632; std 390.53
[ 22 86 -- -- -- -- ]:     0   110     0   651     0  2185     0  4034     0  3009     0     0     0     0     0     0     0     1     0     0 : latency    1498178; std 388.47
[ 22 87 -- -- -- -- ]:     0    76     0   592     0  2125     0  4153     0  3043     0     0     0     0     0     0     0     0     0     0 : latency    1498812; std 393.48
[ 22 88 -- -- -- -- ]:     0   246     0  1108     0  2822     0  3810     0  1984     0     0     0     0     0     0     0     1     0     0 : latency    1492060; std 361.24
[ 22 89 -- -- -- -- ]:     0    84     0   584     0  2180     0  4008     0  3133     0     0     0     0     0     0     0     0     0     0 : latency    1498866; std 390.11
[ 22 90 -- -- -- -- ]:     0   454     0  1797     0  3644     0  3456     0   571     0     0     0     0     0     0     0     1     0     0 : latency    1483192; std 375.04
[ 22 91 -- -- -- -- ]:     0    97     0   580     0  2140     0  4073     0  3103     0     0     0     0     0     0     0     0     0     1 : latency    1498852; std 393.60
[ 22 92 -- -- -- -- ]:     0    76     0   629     0  2217     0  4025     0  3043     0     0     0     0     0     0     0     0     0     1 : latency    1498486; std 388.38
[ 22 93 -- -- -- -- ]:     0    89     0   579     0  2203     0  3969     0  3146     0     0     0     0     0     0     0     0     0     0 : latency    1498944; std 388.98
[ 22 94 -- -- -- -- ]:     0   122     0   831     0  2344     0  3988     0  2691     0     0     0     0     0     0     0     0     0     0 : latency    1496330; std 378.18
[ 22 95 -- -- -- -- ]:     0    88     0   585     0  2160     0  4025     0  3129     0     0     0     0     0     0     0     0     0     1 : latency    1498852; std 390.34
[ 22 96 -- -- -- -- ]:     0   101     0   636     0  2130     0  4085     0  3033     0     0     0     0     0     0     0     0     0     1 : latency    1498422; std 388.90
[ 22 97 -- -- -- -- ]:     0   116     0   597     0  2140     0  3973     0  3162     0     0     0     0     0     0     0     1     0     0 : latency    1498746; std 390.13
[ 22 98 -- -- -- -- ]:     0   209     0  1080     0  2932     0  3816     0  1932     0     0     0     0     0     1     0     0     0     0 : latency    1492050; std 367.12
[ 22 99 -- -- -- -- ]:     0    91     0   617     0  2113     0  4081     0  3080     0     0     0     1     0     0     0     0     0     0 : latency    1498652; std 392.35
0: 35 lat = 1516597
1: 71 lat = 1498962
2: 49 lat = 1498948
3: 29 lat = 1498948
4: 93 lat = 1498944
95: 82 lat = 1478218
96: 04 lat = 1476316
97: 80 lat = 1476248
98: 08 lat = 1472080
99: 00 lat = 1463218
0: 03 std = 396.19
1: 69 std = 396.18
2: 20 std = 395.48
3: 29 std = 395.33
4: 75 std = 395.05
95: 38 std = 366.39
96: 28 std = 363.68
97: 68 std = 363.40
98: 08 std = 361.99
99: 88 std = 361.24
lat_k 0-1 1.18%, lat_k 98-99 0.61%, lat_k 0-99 3.65%
std_k 0-1 0.00%, std_k 98-99 0.21%, std_k 0-99 9.67%
pin[1] choose candidate: 35 (latency only)
[ 22 35 00 -- -- -- ]:     0    11     0    84     0   637     0  1905     0  3332     0  3070     0   958     0     0     0     0     0     0 : latency    1522890; std 342.73
[ 22 35 01 -- -- -- ]:     0     2     0    43     0   306     0  1277     0  3128     0  3589     0  1652     0     0     0     0     0     0 : latency    1529592; std 358.17
[ 22 35 02 -- -- -- ]:     0     2     0    33     0   327     0  1292     0  3217     1  3547     0  1578     0     0     0     0     0     0 : latency    1529159; std 361.18
[ 22 35 03 -- -- -- ]:     0     5     0    35     0   292     0  1307     0  3073     1  3666     0  1618     0     0     0     0     0     0 : latency    1529631; std 362.07
[ 22 35 04 -- -- -- ]:     0     5     0    68     0   388     0  1510     0  3309     0  3306     0  1411     0     0     0     0     0     0 : latency    1527094; std 350.55
[ 22 35 05 -- -- -- ]:     0     7     0    46     0   292     0  1222     0  3149     0  3710     0  1571     0     0     0     0     0     1 : latency    1529616; std 363.75
[ 22 35 06 -- -- -- ]:     0     3     0    49     0   339     0  1323     0  3100     0  3544     0  1639     0     0     0     0     0     1 : latency    1529180; std 354.48
[ 22 35 07 -- -- -- ]:     0    14     0   124     0   570     0  1716     0  3182     0  3064     0  1325     0     0     0     0     0     1 : latency    1524696; std 336.07
[ 22 35 08 -- -- -- ]:     0     0     0    14     0   115     0   590     0  1856     0  3446     0  2990     0   986     0     0     0     1 : latency    1542900; std 343.76
[ 22 35 09 -- -- -- ]:     0     0     0     4     0    37     0   285     0  1358     0  2990     0  3693     0  1630     0     0     0     0 : latency    1549648; std 358.55
[ 22 35 10 -- -- -- ]:     0     1     0    26     0   249     0  1082     0  2630     0  3635     0  2068     0   306     0     0     0     0 : latency    1533914; std 347.50
[ 22 35 11 -- -- -- ]:     0     0     0     2     0    31     0   308     0  1301     0  3139     0  3615     0  1601     0     0     0     0 : latency    1549452; std 359.57
[ 22 35 12 -- -- -- ]:     0     0     0     5     0    36     0   342     0  1323     0  3115     0  3614     0  1562     0     0     0     0 : latency    1549060; std 357.72
[ 22 35 13 -- -- -- ]:     0     0     0     4     0    45     0   311     0  1318     0  3027     0  3683     0  1608     0     1     0     0 : latency    1549474; std 360.73
[ 22 35 14 -- -- -- ]:     0     0     0     9     0    70     0   406     0  1502     0  3198     0  3505     0  1307     0     0     0     0 : latency    1546970; std 353.75
[ 22 35 15 -- -- -- ]:     0     0     0     2     0    38     0   276     0  1282     0  3162     0  3710     0  1527     0     0     0     0 : latency    1549470; std 364.53
[ 22 35 16 -- -- -- ]:     0     0     0     5     0    36     0   291     0  1368     0  3069     0  3773     0  1455     0     0     0     0 : latency    1549062; std 363.74
[ 22 35 17 -- -- -- ]:     0     0     0     5     0    40     0   298     0  1279     0  3123     0  3682     0  1570     0     0     0     0 : latency    1549466; std 361.67
[ 22 35 18 -- -- -- ]:     0     0     0    18     0   124     0   594     0  1873     0  3340     0  3107     0   941     0     1     0     0 : latency    1542816; std 343.54
[ 22 35 19 -- -- -- ]:     0     0     0     3     0    53     0   300     0  1315     0  3082     0  3599     0  1645     0     0     0     0 : latency    1549458; std 356.86
[ 22 35 20 -- -- -- ]:     0     3     0    49     0   312     0  1285     0  3124     0  3573     0  1651     0     0     0     0     0     0 : latency    1529472; std 357.07
[ 22 35 21 -- -- -- ]:     0     0     0     2     0    37     0   293     0  1328     0  3081     0  3660     0  1596     0     0     0     0 : latency    1549492; std 359.69
[ 22 35 22 -- -- -- ]:     0     0     0     1     0    43     0   364     0  1309     0  3025     0  3735     0  1520     0     0     0     0 : latency    1549064; std 359.44
[ 22 35 23 -- -- -- ]:     0     0     0     4     0    43     0   333     0  1323     0  2964     0  3706     0  1624     0     0     0     0 : latency    1549494; std 357.24
[ 22 35 24 -- -- -- ]:     0     0     0     2     0    64     0   440     0  1484     0  3212     0  3456     0  1339     0     0     0     0 : latency    1546992; std 351.95
[ 22 35 25 -- -- -- ]:     0     0     0     4     0    48     0   282     0  1303     0  3149     0  3593     0  1617     0     1     0     0 : latency    1549458; std 361.38
[ 22 35 26 -- -- -- ]:     0     0     0     6     0    48     0   311     0  1358     0  3092     0  3618     0  1564     0     0     0     0 : latency    1549050; std 357.42
[ 22 35 27 -- -- -- ]:     0     0     0     6     0    43     0   299     0  1311     0  3047     0  3699     0  1592     0     0     0     0 : latency    1549494; std 359.92
[ 22 35 28 -- -- -- ]:     0     0     0     9     0   110     0   616     0  1890     0  3360     0  3056     0   956     0     0     0     0 : latency    1542812; std 342.92
[ 22 35 29 -- -- -- ]:     0     1     0     6     0    53     0   333     0  1300     0  3028     0  3588     0  1688     0     0     0     0 : latency    1549474; std 356.54
[ 22 35 30 -- -- -- ]:     0     8     0    21     0   212     0  1038     0  2759     0  3619     0  2026     0   314     0     0     0     0 : latency    1533972; std 350.36
[ 22 35 31 -- -- -- ]:     0     0     0     3     0    35     0   285     0  1220     0  3188     0  3748     0  1518     0     0     0     0 : latency    1549608; std 366.98
[ 22 35 32 -- -- -- ]:     0     0     0     3     0    30     0   314     0  1442     0  3054     0  3491     0  1663     0     0     0     0 : latency    1549142; std 351.99
[ 22 35 33 -- -- -- ]:     0     0     0     6     0    37     0   310     0  1285     0  3070     0  3663     0  1626     0     0     0     0 : latency    1549604; std 359.22
[ 22 35 34 -- -- -- ]:     0     1     0     5     0    54     0   395     0  1550     1  3187     0  3440     0  1364     0     0     0     1 : latency    1547131; std 356.24
[ 22 35 35 -- -- -- ]:     0     0     0     1     0    34     0   276     0  1315     0  3128     0  3675     0  1568     0     0     0     0 : latency    1549530; std 362.16
[ 22 35 36 -- -- -- ]:     0     0     0     2     0    38     0   297     0  1367     0  3119     0  3600     0  1574     0     0     0     0 : latency    1549182; std 358.20
[ 22 35 37 -- -- -- ]:     0     0     0     1     0    46     0   277     0  1281     0  3098     0  3740     0  1554     0     0     0     0 : latency    1549598; std 363.66
[ 22 35 38 -- -- -- ]:     0     2     0     8     0   117     0   623     0  1903     0  3258     0  3100     0   986     0     0     0     1 : latency    1542910; std 342.57
[ 22 35 39 -- -- -- ]:     0     0     0     2     0    55     0   344     0  1260     0  3026     0  3620     0  1690     0     0     0     0 : latency    1549610; std 355.43
[ 22 35 40 -- -- -- ]:     0     0     0    41     0   308     0  1367     0  3138     0  3585     0  1558     0     0     0     0     0     0 : latency    1529048; std 355.58
[ 22 35 41 -- -- -- ]:     0     2     0    64     0   315     0  1285     0  3067     0  3591     0  1672     0     0     0     0     0     0 : latency    1529488; std 357.99
[ 22 35 42 -- -- -- ]:     0     0     0     4     0    33     0   316     0  1316     0  3158     0  3674     0  1496     0     0     0     0 : latency    1549060; std 362.04
[ 22 35 43 -- -- -- ]:     0     0     0    10     0    39     0   342     0  1309     0  2972     0  3674     0  1651     0     0     0     0 : latency    1549506; std 356.02
[ 22 35 44 -- -- -- ]:     0     0     0     9     0    60     0   417     0  1549     0  3222     0  3315     0  1425     0     0     0     0 : latency    1546986; std 347.44
[ 22 35 45 -- -- -- ]:     0     0     0     2     0    38     0   298     0  1277     0  3098     0  3755     0  1529     0     0     0     0 : latency    1549490; std 364.00
[ 22 35 46 -- -- -- ]:     0     0     0     6     0    40     0   357     0  1382     1  3035     0  3544     0  1632     0     0     0     1 : latency    1548985; std 354.48
[ 22 35 47 -- -- -- ]:     0     0     0     3     0    33     0   303     0  1355     0  3056     0  3584     0  1663     0     0     0     0 : latency    1549530; std 355.92
[ 22 35 48 -- -- -- ]:     0     0     0     7     0    91     0   566     0  1972     0  3413     0  3000     0   948     0     0     0     0 : latency    1542834; std 345.40
[ 22 35 49 -- -- -- ]:     0     0     0     0     0     6     0    47     0   374     0  1604     0  3191     1  3395     0  1365     0    14 : latency    1567151; std 355.07
[ 22 35 50 -- -- -- ]:     0     2     0    31     0   207     0  1029     0  2779     0  3629     0  2000     0   320     0     0     0     0 : latency    1533950; std 350.95
[ 22 35 51 -- -- -- ]:     0     0     0     3     0    46     0   328     0  1306     0  2980     0  3685     0  1649     0     0     0     1 : latency    1549592; std 356.99
[ 22 35 52 -- -- -- ]:     0     0     0     5     0    41     0   297     0  1372     0  3118     0  3557     0  1607     0     0     0     0 : latency    1549178; std 356.39
[ 22 35 53 -- -- -- ]:     0     0     0     3     0    30     0   282     0  1280     0  3119     0  3758     0  1525     0     0     0     0 : latency    1549578; std 365.26
[ 22 35 54 -- -- -- ]:     0     1     0     6     0    79     0   425     0  1512     0  3097     0  3487     0  1390     0     0     0     1 : latency    1547128; std 351.49
[ 22 35 55 -- -- -- ]:     0     0     0     1     0    43     0   347     0  1298     0  2963     0  3699     0  1646     0     0     0     0 : latency    1549586; std 356.85
[ 22 35 56 -- -- -- ]:     0     0     0     6     0    45     0   326     0  1368     0  3059     0  3541     0  1652     0     0     0     0 : latency    1549186; std 353.37
[ 22 35 57 -- -- -- ]:     0     0     0     0     0    42     0   295     0  1345     0  3055     0  3591     0  1669     0     0     0     0 : latency    1549592; std 353.90
[ 22 35 58 -- -- -- ]:     0     0     0    11     0    98     0   624     0  1958     0  3293     0  2933     0  1080     0     0     0     0 : latency    1542952; std 336.48
[ 22 35 59 -- -- -- ]:     0     1     0     4     0    38     0   301     0  1286     0  3104     0  3642     0  1620     0     1     0     0 : latency    1549576; std 364.11
[ 22 35 60 -- -- -- ]:     0     1     0    49     0   282     0  1281     0  3143     0  3633     0  1608     0     0     0     0     0     0 : latency    1529566; std 360.61
[ 22 35 61 -- -- -- ]:     0     1     0     0     0    41     0   264     0  1299     0  3112     0  3736     0  1544     0     0     0     0 : latency    1549594; std 364.26
[ 22 35 62 -- -- -- ]:     0     0     0     4     0    48     0   313     0  1266     0  3196     0  3658     0  1512     0     0     0     0 : latency    1549112; std 362.43
[ 22 35 63 -- -- -- ]:     0     0     0     0     0    39     0   292     0  1267     0  3091     0  3761     0  1547     0     0     0     0 : latency    1549630; std 361.97
[ 22 35 64 -- -- -- ]:     0     0     0     4     0    55     0   381     0  1529     0  3324     0  3308     0  1398     0     0     0     0 : latency    1547276; std 349.38
[ 22 35 65 -- -- -- ]:     0     0     0     0     0    40     0   294     0  1304     0  3067     0  3728     0  1564     0     0     0     0 : latency    1549542; std 359.72
[ 22 35 66 -- -- -- ]:     0     0     0     5     0    42     0   281     0  1353     0  3147     0  3609     0  1560     0     0     0     1 : latency    1549186; std 359.58
[ 22 35 67 -- -- -- ]:     0     0     0     2     0    36     0   282     1  1276     0  3136     0  3704     0  1560     0     0     0     0 : latency    1549587; std 365.72
[ 22 35 68 -- -- -- ]:     0     0     0     4     0   110     0   580     0  1984     0  3361     0  2899     0  1059     0     0     0     0 : latency    1542908; std 339.04
[ 22 35 69 -- -- -- ]:     0     0     0     1     0    38     0   261     0  1319     0  3133     0  3646     0  1599     0     0     0     0 : latency    1549626; std 361.43
[ 22 35 70 -- -- -- ]:     0     1     0    28     0   218     0  1111     0  2633     0  3686     0  2003     0   317     0     0     0     0 : latency    1533876; std 349.21
[ 22 35 71 -- -- -- ]:     0     0     0     4     0    31     0   317     0  1305     0  3070     0  3677     0  1593     0     0     0     1 : latency    1549480; std 359.70
[ 22 35 72 -- -- -- ]:     0     1     0     4     0    44     0   370     0  1342     0  3054     0  3535     0  1647     0     0     0     1 : latency    1549038; std 354.49
[ 22 35 73 -- -- -- ]:     0     0     0     6     0    46     0   298     0  1301     1  3096     0  3616     0  1633     0     0     0     1 : latency    1549495; std 360.38
[ 22 35 74 -- -- -- ]:     0     0     0     1     0    62     0   429     0  1546     0  3155     0  3441     0  1363     0     0     0     0 : latency    1546998; std 349.84
[ 22 35 75 -- -- -- ]:     0     0     0     3     0    44     0   264     0  1334     0  3071     0  3739     0  1542     0     0     0     0 : latency    1549490; std 362.94
[ 22 35 76 -- -- -- ]:     0     0     0     2     0    40     0   307     0  1325     0  3201     0  3560     0  1562     0     0     0     0 : latency    1549088; std 359.00
[ 22 35 77 -- -- -- ]:     0     0     0     3     0    45     0   314     0  1331     1  3031     0  3635     0  1637     0     0     0     0 : latency    1549461; std 358.92
[ 22 35 78 -- -- -- ]:     0     2     0    12     0   129     0   594     0  1912     0  3327     0  3017     0  1004     0     1     0     0 : latency    1542808; std 342.42
[ 22 35 79 -- -- -- ]:     0     1     0     0     0    32     0   305     0  1283     0  3121     0  3677     0  1578     0     0     0     1 : latency    1549528; std 361.57
[ 22 35 80 -- -- -- ]:     0     4     0    57     0   412     0  1572     0  3157     0  3434     0  1360     0     0     0     0     0     1 : latency    1526988; std 352.41
[ 22 35 81 -- -- -- ]:     0     4     0    51     0   309     0  1329     0  2975     0  3711     0  1618     0     0     0     0     0     0 : latency    1529520; std 358.02
[ 22 35 82 -- -- -- ]:     0     1     0    51     0   342     0  1318     0  3091     1  3629     0  1563     0     1     0     0     0     1 : latency    1529055; std 361.87
[ 22 35 83 -- -- -- ]:     0     4     0    29     0   315     0  1243     0  3170     0  3689     0  1547     0     0     0     0     0     0 : latency    1529474; std 363.45
[ 22 35 84 -- -- -- ]:     0     0     0     5     0    72     0   439     0  1515     0  3186     0  3351     0  1429     0     0     0     0 : latency    1547012; std 346.84
[ 22 35 85 -- -- -- ]:     0     1     0     1     0    54     0   311     0  1266     0  3098     0  3668     0  1598     0     0     0     0 : latency    1549462; std 362.18
[ 22 35 86 -- -- -- ]:     0     0     0     5     0    36     0   332     0  1360     0  3112     0  3576     0  1576     0     0     0     0 : latency    1549006; std 356.28
[ 22 35 87 -- -- -- ]:     0     1     0     5     0    54     0   306     0  1297     0  3029     0  3704     0  1601     0     0     0     0 : latency    1549472; std 361.53
[ 22 35 88 -- -- -- ]:     0     0     0     6     0   102     0   590     0  1930     1  3444     0  2941     0   983     0     0     0     0 : latency    1542785; std 345.84
[ 22 35 89 -- -- -- ]:     0     0     0     0     0    60     0   317     0  1286     0  3048     0  3659     0  1627     0     0     0     0 : latency    1549482; std 355.50
[ 22 35 90 -- -- -- ]:     0     2     0    41     0   217     0  1058     0  2678     0  3638     0  2041     0   322     0     0     0     1 : latency    1533982; std 348.55
[ 22 35 91 -- -- -- ]:     0     0     0     4     0    31     0   296     0  1312     0  3108     0  3598     0  1648     0     0     0     0 : latency    1549614; std 358.26
[ 22 35 92 -- -- -- ]:     0     0     0     1     0    54     0   304     0  1298     0  3173     0  3607     0  1560     0     0     0     1 : latency    1549160; std 359.75
[ 22 35 93 -- -- -- ]:     0     0     0     2     0    41     0   309     0  1290     0  3086     0  3623     0  1646     0     0     0     0 : latency    1549604; std 358.16
[ 22 35 94 -- -- -- ]:     0     0     0     7     0    58     0   381     0  1523     0  3223     0  3463     0  1342     0     0     0     1 : latency    1547170; std 353.78
[ 22 35 95 -- -- -- ]:     0     0     0     3     0    24     0   306     0  1327     0  3060     0  3666     0  1611     0     0     0     0 : latency    1549586; std 359.39
[ 22 35 96 -- -- -- ]:     0     0     0     1     0    32     0   337     0  1289     0  3153     0  3663     0  1522     0     0     0     1 : latency    1549138; std 361.21
[ 22 35 97 -- -- -- ]:     0     0     0     3     0    39     0   323     0  1298     0  2990     0  3755     0  1589     0     0     0     0 : latency    1549576; std 360.33
[ 22 35 98 -- -- -- ]:     0     1     0    13     0    97     0   611     0  1930     0  3379     0  2917     0  1049     0     0     0     0 : latency    1542884; std 341.74
[ 22 35 99 -- -- -- ]:     0     0     0     2     0    42     0   282     0  1276     0  3083     0  3778     0  1534     0     0     0     0 : latency    1549596; std 364.76
0: 49 lat = 1567151
1: 09 lat = 1549648
2: 63 lat = 1549630
3: 69 lat = 1549626
4: 91 lat = 1549614
95: 40 lat = 1529048
96: 04 lat = 1527094
97: 80 lat = 1526988
98: 07 lat = 1524696
99: 00 lat = 1522890
0: 31 std = 366.98
1: 67 std = 365.72
2: 53 std = 365.26
3: 99 std = 364.76
4: 15 std = 364.53
95: 78 std = 342.42
96: 98 std = 341.74
97: 68 std = 339.04
98: 58 std = 336.48
99: 07 std = 336.07
lat_k 0-1 1.13%, lat_k 98-99 0.12%, lat_k 0-99 2.91%
std_k 0-1 0.34%, std_k 98-99 0.12%, std_k 0-99 9.20%
pin[2] choose candidate: 49 (latency only)
Candidate PIN 22 35 49 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 702 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..done
found PIN: 22 35 49 12 24 94
PIN is cracked in 2779.14 seconds
Validating PIN
PIN verified.
done
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
vtl
Post by vtl »
RickHaleParker wrote: 02 Aug 2021, 01:16 260mA. Not going to over load any USB port
Easily: a 5-port hub connected to already subpar laptop port that drops voltage even before the load reaches 0.5A ;)
Congrats on your successful crack.
RickHaleParker
vtl wrote: 02 Aug 2021, 10:14 Easily: a 5-port hub connected to already subpar laptop port that drops voltage even before the load reaches 0.5A ;)
They do make USB hubs that draw power from a external source.
Active
Past
5ft24
Year and Model: 2005 XC90 V8 AWD
Has thanked: 20 times
Been thanked: 12 times
Post by 5ft24 »
But who wants to pull an extension cord to the car to plug it in...
RickHaleParker
5ft24 wrote: 02 Aug 2021, 14:03 But who wants to pull an extension cord to the car to plug it in...
The one I have runs off 5V and has a USB port for power input. Use a high current 12 - 5V USB adapter.
Google "Powered USB Hub" and take a look.
At least on the CEM-H the 12V receptacle turns on when the CEM goes into programing mode.
Active
Past
