Attachment points for hoisting engine & trans Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I'm almost ready to lift out the engine, and I was wondering about the obvious. Where to attach the chains to lift it ? I have read the tutorial here on how to remove the engine, but most of the pictures don't download for some reason. It refers to attaching a link on the passenger side, but without a pic I don't know what he was doing. Roberts video seems to show a strap being used somehow. So where are the best points on the block to bolt chains / straps to lift everything up and out ? The load leveler has some angle brackets on it, but I don't see them bolting up anywhere.
1999 V70 GLT
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
There should be a lifting point over on the accessory bracket area on the passenger side of the engine by the PS pump, and one by the upper torque mount on the driver side.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Sveedy
Post by Sveedy »
Thanks much ! ! So do I disconnect the torque mount from the firewall ( looks like a PITA ) or just pull the center bolt ? Seems like the whole torque mount arm will be in the way unless I remove it.
1999 V70 GLT
Chuck W
Post by Chuck W »
Sveedy wrote: 08 Aug 2021, 20:01 Thanks much ! ! So do I disconnect the torque mount from the firewall ( looks like a PITA ) or just pull the center bolt ? Seems like the whole torque mount arm will be in the way unless I remove it.
Just remove it from the mount the firewall (the one vertical bolt), as well as from the engine itself.
The picture posted is of an RN (99+) engine, so the location points are a bit different, but still in the same location.
