Attachment points for hoisting engine & trans Topic is solved
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
I'm almost ready to lift out the engine, and I was wondering about the obvious. Where to attach the chains to lift it ? I have read the tutorial here on how to remove the engine, but most of the pictures don't download for some reason. It refers to attaching a link on the passenger side, but without a pic I don't know what he was doing. Roberts video seems to show a strap being used somehow. So where are the best points on the block to bolt chains / straps to lift everything up and out ? The load leveler has some angle brackets on it, but I don't see them bolting up anywhere.
1999 V70 GLT
1999 V70 GLT
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 336 times
There should be a lifting point over on the accessory bracket area on the passenger side of the engine by the PS pump, and one by the upper torque mount on the driver side.
- RickHaleParker
- Been thanked: 958 times
- Sveedy
Thanks much ! ! So do I disconnect the torque mount from the firewall ( looks like a PITA ) or just pull the center bolt ? Seems like the whole torque mount arm will be in the way unless I remove it.
1999 V70 GLT
1999 V70 GLT
- Chuck W
Just remove it from the mount the firewall (the one vertical bolt), as well as from the engine itself.
The picture posted is of an RN (99+) engine, so the location points are a bit different, but still in the same location.
