97 960, going to grab some parts off a 960 with only 87K.
Will be dragging enough tools without adding all my big sockets to the mix.
I'm thinking 32mm or a 36mm. Rather take the single socket than the weight of extras.
Plan on getting quite a few low mileage parts.
Thanks Dave
Hub nut size on 960 front hub
- Has thanked: 987 times
- Been thanked: 1075 times
If you are talking about wheel hub nuts, just take a large adjustable wrench. The torque will not be high enough to risk rounding the nut corners. One wrench will fit any size.
dm635
- Year and Model: '96 965
- Been thanked: 14 times
Thanks for the suggestion.
I've pulled these off before. It takes my 3/4" breaker bar and socket. Have to stand on it and bounce. Adding these tools adds weight with all the tools I'll be carrying.
And at this yard the 960 is at the farthest corner. A good little haul. I'll already be taking more tools than usual as I plan on grabbing quite a few parts from this car.
Being lazy I guess, when I can jack my car up, pull the wheel and pop off the hub nut cover to select the proper socket.
Asking seems easier.
96-964
09-V70
05-325i
86-635CSi
Previous- 83 245T, 84 242, 85 242T, 92 960, 94 960, 95-964, 95-945, 91-780t, 96-960, 98-XC, 91-745,
09-V70
05-325i
86-635CSi
I would bring all the sockets. I’ve had instances where aftermarket axle nut hex sizes were different from stock on bmws. 30mm 32 mm 36mm.
My E83 has a Rein front axle nut that is different from the other at the moment. It was something like $35 bucks cheaper
- 1073 Views
Last post by zombielinux
- 11 Replies
- 1262 Views
Last post by jonesg
- 15 Replies
- 2021 Views
Last post by volvolugnut
- 2890 Views
- 1403 Views
