V70 XC, operates normal in reverse, accelerates slowly at first in 1 Topic is solved
Rocket999
Year and Model: 2000 V70 XC
Post by Rocket999 »
It is normal in reverse, does have a good (new) clank jerk going into reverse, otherwise normal in reverse
put it in drive it needs serious revs to get it movinmg at all, if I was at the bottom of a hill Id need a tow truck
Diagnostics so far:
- seemed like not enough ATF same as in an earlier episode, topped up ATF castrol Dex/merc III, it had lost more than I realized recently but that did not correct it
- with all 4 wheels off the ground, the wheels rotate apparently normally with engine and transmission engaged both revers and drive
- with engine off in N and D and R , all four rotate easily, fronts a little "thicker" takes more effort
- when it does roll forward, with abnormal high engine revs, ... there is a new odd sound whirr whish sound when revs are spinning up
- seems a bit like maybe torque converter isn't delivering torque to trans, except in reverse .
Thanks for any comments in advance
you guys really helped me thru a rough time
thx again
Rocket999
Post by Rocket999 »
with all 4 wheels off the ground and spinning driven by motor, touch the brake pedal, horrendous crunching grind from front brakes, and wierd rather strong vibration through the brake pedal
Get a look at the brakes next .... i jumped on them during the accident, they should handle that.
Rocket999
Post by Rocket999 »
Much better now after 2 atf top ups
reverse still normal
in D it moves forward slipping a lot .... at 5 to 7 mph becomes seems normal
in position 1 it pulls away stronger .... then at 5 to 7n mph beccomes normal
Rocket999
Post by Rocket999 »
volvo shifter.jpeg (143.65 KiB) Viewed 1342 times
Engine running perfect
This is AW50-42LE transmission
Owners manual is equivocal on wither it is 4 vs 5 speed
starts from stationary real real slow, then seeming normal above 5 or 7 mph
I wonder is it stuck in winter mode with sluggish moveing from stationary
After collision:
no more vertical arrow on dash while in postion 3,2,or 1
no more horn
the posted gear shift lever ..... P N D 3 2 1 robert says it is 5 speed
can anyone comment or verify, is this 4 spd or is it 5 spd?
Oly850
Year and Model: In acquisition mode.
Has thanked: 53 times
Been thanked: 22 times
Post by Oly850 »
Your Park Neutral Position switch on top of the trans might be knocked loose after a crash. It communicates to the car computer, opens and closes solenoids, etc. How many miles on the trans? Have you done a full drain and looked in the pan?
Looking for a V90 to be my next Volvo, at the very least a T5.
2017 XC90 Inscription - My best Volvo by far, but Ex-wife departed & I had to sell. 😕
2001 S80 T6 - rebuilt trans, head gasket, fixed & sold
1997 V70 - kid car, sold
1996 850 GLT - found under bridge, 2 year refurb project, commuter car, kid car, T-Boned - SIPS saved passenger. Totaled.
1997 VW GTI VR6 - exceedingly fast.
1971 VW Type II/231 - it was pointed out by management that the children would be killed in it.
Rocket999
Post by Rocket999 »
Thank you for your input
Robert S. thinks this AW50-42 may be a 5 speed, I say 4, according to transtec website
Trans: about 120K
I replaced the PNP about 2 years ago, so its age isn't it but a jarring crash may have
never took the pan off
did a dexIII mrc flush yesterday but never took the pan off.
what would one look for inside the pan??
I get the impression stuck in winter .... ie gears 3 and 4 only
Rocket999
Post by Rocket999 »
Trans: about 120K
I get the impression stuck in winter .... ie gears 3 and 4 only, slow to roll from stop, normal once it rolling
vertical dash arrow light no longer lit in position 3, 2, 1 as it was before crash
Been thanked: 4065 times
It’s a 4 speed. Aw55-xx denotes a five speed.
Look at the plate in the transmission to confirm. Don’t rely on paperwork and internet for point info like this
If you used an aftermarket pnp, they suck
Try this test. Drive the car with and without the W button depressed. It should be noticeably different on driving from a stop.
If it isn’t, you are stuck in W mode
Rocket999
Post by Rocket999 »
Thank you sir
inspecting trans label, on top of trans along mating with engine: its AW50-42 LE, my understanding is 4 spd, thx for confirm
PNP is from Volvo
The W button does not seem to change the way is operates far as I can tell, button does not light up,
Bit sounds like you are stuck in W
My daughters dog likes to push the W button on her Car on the highway. You don’t notice it until you stop , then go to restart and have no power ( your car is in 2 or 3 gear and torque is reduced )
